Does my T-ReX dyno sheet look normal?
LS6 SS, well my tuner was adding fuel, but the air fuel ratio wasnt moving. He said for every fuel table he adds, the air fuel ratio moves about a whole point. Nothing was happening with my car. Put the injectors in and instantly it was almost dead on where he wanted the air fuel ratio to be. I maxed out my injectors because in a 6 speed, I'm pushing around 450 rwhp. I put down 420 rwhp back when it was a 6 speed, with the C2 cam, and tons of mods ago. If I picked up 35 rwhp with this new cam, add that to the power I was putting down before, theres 455 rwhp right there. Plus all the other mods I did as well. I've been told that the stock injectors handle around 450 rwhp. It only puts down roughly 400 rwhp now because this is through an automatic, loose unlocked converter, 12 bolt w/4.10 gear, and on slicks. My tuner says he put in 30º of timing, but I've been told that is a bit on the high side. My stock injectors were 26 lb. by the way.
Got Me SOM, why do you say I'm out of fuel? The air fuel ratio is good now and I just upgraded to the SVO 30 lb. injectors.
