G5X2 with FFHP heads
These are Superflow dyno numbers:
428 RWHP
400 RWTQ (I can't remember exactly what my tq number was, but it was right at 400)
What do you guys think? I REALLY wanted 450 RWHP. But, I am not dissappointed at all. Up next on the mod list is a pulley and ported throttle body. Hopefully that will get me close to that mark.
you dont hit 350 till 3600rpms,
who tuned your car?
is it tuned well?
is your cam installed dot to dot? could be a degree off.
your high end HP falls off early too for a cam that size.
every car is different but i would be really disapointed, my numbers and curve were better with less mods a 224 cam and a whole lot of oil getting passed the rings.
Dyno's are used as tuning tools.
The graph shows a nice smooth HP and TQ curve with a good AFR.
the dyno used is a superflow SF-840 dual eddy current style dyno and may have had the car under a load as opposed to a dyno-jet inertia style dyno.
Dynojet numbers are inflated and everyone should know that.
A dyno is a tuning device to show a gain.
Also he has higher flowing heads than stock so the car is getting more air so the cam does not have to rev as high to make peak power as a car with stock heads would.
What did your car run again xttc2000?
