Finally, Dyno Results on 235/240 Cam!
What cmpression are you running? I ran a similar cam and got a lot from bumbing up the compression to over 12:1. I ran my 224/230 114 with over 11.4:1 too. Remember each point it 14 rwhp but it does even more impressive to the mid and low rpm numbers. Good run.
Would you believe I'm still running the stock compression ratio? I'm sure I could gain a lot by upping the compression, since the overlap in this cam is bleeding some of it off. I didn't have time on this go around, but the next time I have them off, I'm going to mill them and do some more porting. Maybe even install some bigger valves. Of course with this cam that will necessitate notching the pistons, but I don't have a problem with that.
