04 Whipple Cobra dyno!
cobras dont make for even average drag cars. most are in the 3900 lbs raceweight with their IRS and radial tires it isnt easy.
i ran 11.59 @ 116 at 3400 lbs. same 328 rwhp.
my point is give the mustang a break. its all about the setup.
I think the 03-04 Cobras are bad *** rides.
They are hard as hell to launch, because they actually make torque, and they make it instantly. My friends 03 with pulley exhaust tune was making 499rwtq.
Our cars with H/C might make 420rwtq and it isnt till 3500-4500 rpm.
as for the big mustang dyno numbers, i have a feeling it was on a mustang dyno but the final numbers are in "dynojet conversion numbers" where it adds a percentage to make it comparable to a dynojet. too many operators do that but people get mad when their loaded numbers are lower than dynojet dynos.
again just an observation.
Nah wise guys.... you know a clutch is slipping when certain things happens:
1. You hit the rev limiter even though the car almost moved. (Not Wheel Spin)
2. The pedal feels mushy at the end and in some really bad cases it sticks to the floor.
3. Really bad smell that lasts the whole time until u reach home.
My problem on that run were that i was still doing under 100mph when i had to shift to 4th gear due to clutch slippage. I hit the Rev limiter 7000RPM before the end of the run although i was running 26inch street tires and 3.73 gears which means they are good for at least 138-141mph (Depends on which gear calculator u go with) before i should see the limiter. I never aborted the run because the clutch pedal was still coming back and i knew that was my only run for the day.
After i let the clutch cool down for few hours.... I did a 2nd run if u want to know and i got 2.8 60ft and the clutch pedal never came back up. Ofcourse i ran 27 sec at 38 mph.
I guess u never had a chance to blow a clutch. I have been through 3 so far so i know when a clutch is slipping ok. Next time think about what you are saying before you type.
