Awful dyno numbers need advice
Old Aug 25, 2005 | 06:02 PM
  #41
JB151's Avatar
If the clutch was slipping the third dyno run would not have been the strongest. Also there would be an odor after three dyno pulls on a slipping clutch.
Old Aug 30, 2005 | 01:18 PM
  #42
hitemup9nine's Avatar
Yeah, I think I have the same problem. Full bolt-ons i dynoed 315hp and 310tq. With the f13 cam and underdrive pulley I dynoed 361hp not bad for an a4 but with a lousy 338 in tq. I only gaing 28lbs of tq with cam. Hp isnt too bad but whats up with my tq. Hope you or I find the answer.
Old Aug 30, 2005 | 03:46 PM
  #43
BlackZCamaro's Avatar
My car too was a higher torque motor than horse before I did the cam, and now its a a respectable 360 horse and it barely made 350 tq. it used to put out 316hp and 332 tq.
Old Sep 14, 2005 | 08:42 PM
  #44
FUN LS1's Avatar
That sounds real low... I pulled 335 rwhp/345 rwtq (Mustang Dyno) with stock heads, cam, and intake; just the bolt-ons in the sig. I'd be expecting at least 390 rwhp, if not over 400
gl, dude
Old Sep 14, 2005 | 08:57 PM
  #45
MiaSSmaro98's Avatar
mysterys??
Old Sep 15, 2005 | 10:16 AM
  #46
mochiles's Avatar
Most of the time when one does a big cam install the TQ curve doesn't grow near what the HP curve does. My car for example made 346hp / 358tq with full bolt-ons minus the pulley. After my cam install (F13 on 114) I made 387hp / 369tq. Granted this is with a mail-order tune. Doing the math, I gained 41hp but only 11tq. The weather was different when I dynoed as well as where I dynoed so who knows. But who cares they are just numbers.
Drew
Old Sep 15, 2005 | 11:00 AM
  #47
ddnspider's Avatar
i wasnt sure of the specs on that cam so i looked it up; 237/242, .603"/.609", 113 LSA.Thats a pretty heafty camshaft. i made 15 hp less with the GT2-3 cam and midlengths and about the same tq.somethings off,if the compression was good and the A/F was good id check the rockers thats been stated and id check the plugs and plug wires,whats the gap on them?if u want i can host the pics,send it to nickstix@earthlink.net and ill post it tonight.
Old Sep 17, 2005 | 04:19 PM
  #48
HectorLS1's Avatar
Wow that is a huge cam. I'm having the same problem, I'll post my graph later. I'm only making 417 with a 230+ cam, full bolt on's, and TEA 1.5 heads. I was expecting 440hp.
Old Jan 22, 2006 | 01:30 PM
  #49
JB151's Avatar
Here's the dyno finally. Got my Textralia installed finally and will head to the track next time weather permits.
Old Jan 22, 2006 | 01:41 PM
  #50
JB151's Avatar
Doesn't look to me like the clutch is slipping. Remember this is the 3rd dyno run in a row and produced the best results. If the clutch was slipping wouldn't the numbers go down each run?
Old Jan 22, 2006 | 01:56 PM
  #51
TroubledWine3's Avatar
I'm with you, man, I made 345rwtq. in my 98 Z with the mods in my signature. Something is definitely up, bro. I hope you get this figured out.
Old Jan 22, 2006 | 04:11 PM
  #52
slimcracka's Avatar
maybe the dyno is off..he said that a full bolt on car..only made 305..maybe the dyno is off a lil bit..not so uncommon....i would either run it a the track or go to a new dyno and just get some #s...
Old Jan 22, 2006 | 05:26 PM
  #53
DrkPhx's Avatar
I would degree the cam to confirm the specs.
Old Jan 22, 2006 | 07:56 PM
  #54
BLK02WS6's Avatar
Try another dyno and wideband to verify both! I've seen dynos vary plenty. And if the wideband was off, the tune could be off. Easy to go somewhere else and get a second dyno.
Old Jan 22, 2006 | 08:32 PM
  #55
CRL 01 SS's Avatar
I agree with BLK02WS6. It sounds this dyno is off if a full bolt-on LS1 only made 305 rwhp. It'd be worthwhile to get it dynoed somewhere else to confirm the numbers before you have the cam taken out. If the numbers are the same at the second dyno then there is something wrong with the cam or it wasn't installed properly.
JB151, my car is an M6 with the MS3 and has a 9" w/ 4.11s. My car had an LS6 intake when it made these numbers. I installed a Moser 9" before the cam swap, and a Powerbond pulley was installed with the MS3.
These are my Dynojet numbers before and after my MS3 was installed:
Stock Cam, Full Bolt-Ons, 10 Bolt w/ 3.42s - 345 rwhp / 361 rwtq
MS3 Cam, Full Bolt-Ons, 9" w/ 4.11s - 401 rwhp / 364 rwtq
Also, the stock clutch might not have anything to do with the low numbers, but it's not going to hold up very long with the MS3. Hope you get your problem figured out!
