Dyno and 1/4 comparison
Old Aug 27, 2005 | 11:00 AM
68ss_00ss_87_95's Avatar
Default Dyno and 1/4 comparison
2000 SS m6 dynoed at 440/430 with 7# with the p1sc and i used my auto math book to get a rough estimate on 1/4 mile times...according to the equation i should be hitting near 12.0-12.5 but i was wondering what other people have been running cause after i started getting better at launching i pulled out a 13.243@112.23. ive ran the car at the track 8 times so i figure i still have some practicing to do...theres a guy at the track (new england dragway) with a z28 with cold air and slp exhaust running practically the same....i would like to break 12's next time i go, any help would be appreciated....
Old Aug 27, 2005 | 11:02 AM
Magnet's Avatar
holy crap if your really have 440/430 you should be runnin alot faster than that....my guess is oyu have crazy traction problems...get some sticky tires and you will see that et drop a bunch
Old Aug 27, 2005 | 11:19 AM
Checkmate's Avatar
What was your 60 foot? Were you shifting at or near 6000rpm?
With that kind of power you should be running low 12's/high 11's depending on your 60'.
FYI with 340/358 I ran 12.72 @ 111.7 2.05 60'
Old Aug 27, 2005 | 01:13 PM
Rays C5's Avatar
Ahhh .... that much should be mid to low 11s hooking up... Spend your time and effort on 60ft time, driver factor, and more than anything else some sticky tires. I'm surprised your mph was'nt much higher??!!!!
Old Aug 27, 2005 | 02:19 PM
im new to the track scene but im getting better, my 60 ft was 2.2 at best i keep hitting 2.5 and between... heres some of my other runs from friday
r/t 60' 330 1/8 mph 1000' 1/4 mph
.939 2.547 6.372 9.354 84.48 11.812 13.884 107.39
.899 2.277 5.912 8.804 85.35 11.220 13.300 107.39
.783 2.533 6.744 9.793 81.00 12.255 14.329 108.80 <=no traction
.646 2.280 5.918 8.797 83.99 11.207 13.243 112.23
.763 2.510 6.183 9.073 85.43 11.496 13.550 108.48
the last run was w/ an evo8 his numbers were...
.975 1.808 5.919 9.079 80.86 11.897 14.693 76.17
if i could only get a 60' like his id be hittin the 12's but like you guys said traction...what should i do bsides tires? im gettin some subframes and finishing my exhaust now
Old Aug 27, 2005 | 02:21 PM
im shifting at 6000...the boost makes up for some of the slack from my launches...
Old Aug 27, 2005 | 02:26 PM
Wnts2Go10O's Avatar
yea u need traction BAD. lol decent trap though, not the greatest but decent. the trap speed is a better indicator of power as u could gear it right and run 10's..
Old Aug 27, 2005 | 02:34 PM
Wnts2Go10O's Avatar
slip the clutch and i guarentee ur 60's will be 2.0's also if u feel her slip pedal it ever so slightly.
Old Aug 27, 2005 | 03:01 PM
BPLS1's Avatar
id b pretty pissed if i was running 13s still with that much hp, i think even i can break a 12, slicks would b very helpfull
Old Aug 28, 2005 | 07:57 PM
Rays C5's Avatar
There are plenty of guys on here withno sfc or any suspension(stock) changes that are in the 11's . Believe me tires and some good driving(launching) will get you some very low 12's or 11's. I know 2 guys personally with hp in the 370 range with 3.07 gears but 1.6x 60 ft times getting 11.70's.Mines with 343hp on a 1.80 60ft times was 12.43. This might cause a flame butwith street tires I could'nt get into the 12s until I changed converter and got some drag radials.
Old Aug 30, 2005 | 08:29 PM
demonspeed's Avatar
It's not mine! woo hoo!
Something is wrong. That trap is horribly low for having that much power. You should be trapping around 117 with those shitty 60's and that bad e/t. There is no reason why you shouldn't be going 120+ once you get more power to the ground though - but still, 108-112 is horrible for that amount of power.
Old Aug 30, 2005 | 08:33 PM
REDSS01's Avatar
Old Aug 31, 2005 | 04:20 AM
roadrash9r's Avatar
where did you get dynoed at? I woud have to agree those traps are slow. And mph is a measure of horsepower, not et.
Old Aug 31, 2005 | 05:22 PM
i got dynoed at f1dyno in portland maine, they do SAE on theirs...im gonna try leavin the traction control on for a launch to see if it will improve
Old Aug 31, 2005 | 05:29 PM
demonspeed's Avatar
ASR is going to make your e/t suffer, so just keep it off. Your 60's aren't even that bad though. With 108-112 traps, it seems as though you're only making around 330 rwhp. Something is messed up, or maybe you shift way too slow or something.
Old Aug 31, 2005 | 08:29 PM
TNTramair's Avatar
yeah....defenitly something wrong here...im trapin 114-115 on just the motor...cam only..with 393rwhp....you should be trappin somewhere between 117-120 with that much power...traction is a problem, i know the feeling, but it still doesnt make up for trap speeds....if anything, when you spin, your traps will be higher than if you get a great launch. id look into your tune.
Old Aug 31, 2005 | 08:44 PM
brad8266's Avatar
I have no suspension mods at all and I ran a 12.2 @ 118 on street tires. If I had good tires I would be in the 11's. Its all in the 60Ft. If I had some stickys and could pull a 1.7 i would be like around 11.5.
