42hp & 26 ft/lbs tq gain
The blue run is from a few months ago, with an air lid/catback.
The green run is last night, I added pacesetter LT's, ORY, and an LS6 manifold. I started the night with 335 hp & 342 ft/lbs tq and was able to squeeze out a few more hp for a final run of 351 hp & 355 tq (STD). Not too shabby...can't wait to get back to the track now that I have retuned it (was going 8.4 two weeks ago).
It also picked up 5hp with the MAF screen removed. And no the car was not allowed to cool between runs...no tricks, just straight up gain 5hp w/o the screen.
I was told that taking the MAF screen off wasnt a good idea and that it did nothing for the car as far as hp increase. Also that keeping it on it actually helped out with hp because it straightens the air flow ? I dunno.
yea i dunno if you've ever heard of this but theres this thing you put on your intake called a "Tornando". its from those late night infomercials but it supposidly spins the air causing it to swirl in the intak better or sumthin... i dunno if they make em for fbodies or if theyre universal or wut but my friend with a s10 says he gets about 3-4 mpg more because of it...
The "Tornado" guys and your buddy must be smoking the same stuff
If you do a search, there's actually a thread on here with proof from a consumer reports type organization that the "tornando" causes a loss in power and mpg and is not cost effective in anyway, sort of like the smooth bellows and TB bypass mods. Neither of these have any support that they actually do anything, If somone can show me otherwise, I would love to see it.
-Andre
Originally Posted by s346k
isn't the maf screen there for a reason? am i the only one who, upon inspection of the maf screen, found crap stuck to it? this crap would've otherwise been ingested by my car. the 5hp gain isn't worth the risk to me. just my .02
Removing the screen is a cheap way to lean your tune a little (on a stock PCM) If you already have a decent A/F ratio, you will probably pick up some KR....
Originally Posted by waSStock
uhhh...fix your leaking air filter...If you have crap in the screen, it is getting through your air cleaner (or lack of)...
I have never had a problem with anything getting past my filter anyway, so I am not concerned with that.
