TR224 owners inside!
I have just done all the free mods including taking porting the hell out of the throttle body. I downloaded the tune to check out what numbers for timing and such the car is recieving at wot and it has a max of 19deg timing. I have done a few 1/4 mile passes and there is 0 knock. Also looks like the part throttle map is the same as a stocker. Car does not surge at all and does pull really hard but the question is with so little timing does the car have enough power to make 400?
I will be retuning it this weekend on a dynojet Elevation 200ft and should be in the mid 60's
Any suggestions from peeps with 224?
I think 400 is a very realistic possiblity for ya. Good luck!
I am thinking if it will take 6 deg more timing there is 10 hp left in it but not sure.I am saving my money for some afr's
380.56RWHP / 375.75 RWTQ SAE
389.93RWHP / 384.78 RWTQ STP
AFR was 12.9x - 13.06
Temp 89.9*
Humidity 36%
Pressure 30.29 in-Hg
On a side note the eibach pro kit is coming off. When I put my car on the dyno and we were strapping it down I noticed the exhaust pipe above the panhard bar is chushed!!! I believe I may need a new exhaust from the intermediate pipe back or at least the 1 pipe that runs over the axle. I may have a little HP in there...cutout, and some simple stuff might get me over the hump.
I will post a graph later. I am tired, just got in from Mobile 20 min. ago.
Mods are listed on my web page. Heads/TR 224 cam/jet hot headers and Y-pipe.
If you got 387 on the Mustang and lets say 405 this time on a dyno jet, it may not actually be producing more power.
If your only concern is dyno numbers go for the Dyno jet, but there is no real way of comparing them.
Personally, I'd go back to the same Mustang dyno. There will still be a variance, but it should be minimal. As temp/humidity factors are equaled out with correction equations. Thia way you'll be avle to better gadge if the mods have had any affect or not.
