how much hp should i make?
with that setup my car made 385rwhp/380rwtq untuned and through an unloked convrter before my rod bolts went
on its first pull so now im looking at putting this same setup on a zl402 iron low compression block till i get a super charger my question is what kind of numbers should i put down?
p.s. sorry for long post
here are specs on motor
Built entirely from brand-new parts.
Sold outright, no cores required!
GM LQ9 iron 6.0 liter block (includes block plugs)
4.000" Eagle 4340 forged steel crankshaft, balanced to rotating assembly
4.000" Ross 2618 forged alloy pistons with -28.50cc dish (includes new rings and full-float pins)
402-CID displacement
Eagle 6.125" H-beam rods
Includes new, factory-installed cam bearings; Clevite rod and main bearings
9:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
and the car made 406rwhp/446rwtq with a unlocked
fuddle 3800tc and 3:73 gears with an 8.5:1 compression ratio but i need to get bigger injectors and ill make some more power but i need to break the motor in a little more before i can do that,but now my problem isnt power its traction lol oh yeah ive decided i will turbo the car but not till some time in the near future
