Mustang dyno ? dyno sheet inside
Old Oct 21, 2005 | 04:30 PM
oange ss's Avatar
Default Mustang dyno ? dyno sheet inside
what is the standard conversion from Mustang to DynoJet numbers ? I dynoed on a DynoJet in April and got 376 rwhp, I dyno'd today on a Mustang and got 362 rwhp. I know I didnt lose 14 rwhp and my trap speed at the track is between 111.9 - 112.7. The guy at the dyno said there would be a little difference but not much, I told him my dyno numbers didnt jive with my trap speed at the track or my butt, cause I know my car runs way better now than it did in April. thanx
Old Oct 21, 2005 | 04:33 PM
oange ss's Avatar
the fueling is way off if you're wondering about the dip or the torque...AFR started at 13.8 and topped out at 14.2...I'll fix it when I get my heads on
Old Oct 21, 2005 | 07:31 PM
DynoDR's Avatar
You may get all kinds of estimated # for a conversion but there is NO such thng. Best thing is to stick to the same dyno or get a baseline test before any changes are made.
Don't sweat it, it is just a number!
Old Oct 21, 2005 | 07:34 PM
oange ss's Avatar
which is one is right ?
Old Oct 21, 2005 | 10:21 PM
mrr23's Avatar
that's a debate that will never get end.
Old Oct 22, 2005 | 11:32 AM
oange ss's Avatar
like I said before track times say 389-394 rwhp....there's absolutley no way my car lost 14 rwhp since April...there has to be some kind of calculation for the offset, I know it's just a number, but the Dynojet is almost an hour away, while the Mustang is 5 minutes away,but the owner of the Mustang is kind of a douche bag...I wanted to get good before and after numbers from the head swap, but the current numbers have me a little down, if they're correct
Old Oct 22, 2005 | 11:49 PM
ls1wannabe's Avatar
you know you put down on the mustang dyno so use that one as ur baseline for before and after heads, also from what i hear mustang dynos are more accurate, what times are you running at the track and what mods do you have
Old Oct 23, 2005 | 11:08 AM
oange ss's Avatar
i'd rather not say, but the trap speed is listed above, mods:TR 224/.563 114 LSA cam, Hooker long tubes, SLP pulley, Shaner S2 tbody, SVO 30 lb injectors, Racetronix fuel pump kit and a bunch of suspension stuff
Old Oct 26, 2005 | 09:03 AM
BAIN's Avatar
In my personal experience, the Dynojet was about 13% higher than the Mustang Dyno. I dynoed on the Mustang dyno and then a week or so later on the Dynojet and they were just about 13% different. But, I think the difference is different for each car. I know that the Mustang dyno is more accurate because it accounts for load, etc. I just got Dynojet numbers because it's easier to spit them off to some people without having to explain why the numbers are so "low".
Old Oct 26, 2005 | 09:48 AM
oange ss's Avatar
i think the Mustang Dyno is more dependant with the operator than a Dyno Jet would be, I noticed the load setting was set at 4% grade.....Mustang is better for tuning than a Dyno Jet, because of the loading factor
Old Nov 3, 2005 | 11:50 AM
01bird58's Avatar
my bro got his SS dynojet dynoed at 425rwhp and at a Mustang dyno at 401rwhp, Mustangs are supposed to be more accurate
Old Nov 3, 2005 | 01:36 PM
lilbuddy1587's Avatar
Actually dude, your trap times are inline with what you put down. I trapped 112 with 352/359 and thats bolt-ons only. If your car isnt tuned properly then you are gonna be missing quite a few ponies.
Old Nov 3, 2005 | 10:39 PM
Mazzenger's Avatar
A long while back I dynoed 370 on a dynojet and 348 on a mustang dyno.
I would trap anywhere from 112 - 114 depending on weather and traction.
Old Nov 4, 2005 | 06:33 AM
brad8266's Avatar
dont worry about the difference, **** even two dynojets wont give the same hp output for the same car. No big deal, timeslips are more important anyway.
