whats wrong
we just dynoed my friends car and i think its bit low what do you guys think?
the car is 99 m6 z28
mods:
flowtech long tube headers
true duals
ls6 intake
bbk 80mm throttle body
spec stg 3
almu flywheel
air lid (stock filter)
stock gears
no tune
the car dynoed 318rwhp 327rwtq is it good?
I agree totally, to many people read far too much into dyno numbers. And besides the mods listed are no where near FULL bolt ons, and there is no gaurantee they all make power.
mods:
flowtech long tube headers - yes these should imporve BHP, but if it started with 280-300 rwhp it has gained. Also a tune would be worth while.
true duals - what setup, you could easily loose power with a poor dual setup, it's all about flow rate. What mufflers are used.
ls6 intake - again it should make power, but was it definatley an LS6 intake? Many people have bought 2nd hand ones only to later find out it's an LS1 intake. A tune is vital
bbk 80mm throttle body - again no tune = pointless. Plus the stock TB actually flows pretty decently.
spec stg 3 almu flywheel - only minimal gains on a dyno, but should improve throttle response
air lid (stock filter) - again....
stock gears - so
no tune - probably the biggest culprit
the car dynoed 318rwhp 327rwtq is it good? - yes and no. A tune has the potential to find another 15-20rwhp. And there's no way a car with those mods should be making more than 340-350rwhp.
Plus as mentioned already, what type of dyno was it on? Even the tyre pressures could have effected the results by 1-3rwhp.
true duals
ls6 intake
spec stg 3
almu flywheel
stock gears
no tune
