Is This Right Or Is There More To Be Gained
Other mods are in sig. Any imput would be appreciated. Thanks guys!edited for caps. -Brandon
Last edited by Brandon; Nov 26, 2005 at 12:11 PM. Reason: TURN YOUR CAPS LOCK OFF.
See how much nicer things are in lower case.
Post up a graph of the dyno run. Also, what did the car dyno wen stock? Those 18" wheels aren't helping your dyno numbers either. Judging by your sig i'd say you're still missing quite a few bolt ons which is leaving a few ponies on the table.
oh and i edited your post for your caps typing.
i say take it to the track,dyno numbers aren't everything.
I've done cars with more power on a smaller cam and less boltons, so I'd say there's something missing.
i'd say he's missing a whole lotta power, even without the boltons.
and if you wanna do the little boltons, remember that they're all tiny, and make sense only really when you do them together. but then you add up the money (300 intake, 100 TB, 200 pulley) and you realize how much money you just dipped into 20 hp and it kinda sucks. so make sure that bang per buck is there.
Did you see the AFR on the dyno and know what timing is in the car? Don't be so quick to think that because the tuner was a friend of a friend that he is to blame. I've re-tuned some cars done by some so-called major shops and let me tell you - just because they take out full page color ads in magazines doesn't mean they can tune! Get some logs on the car and see what is going on - that will tell you more.
