Help with dyno results - low HP
Old Jan 7, 2006 | 12:33 AM
JGA's Avatar
JGA
Default Help with dyno results - low HP
Hi
98 A4
K&N induction
Mac Headers
Mac cat y pipe
Borla cat back
MSD coils
Recent compression test was excellent. Car runs fine. No engine codes. New plugs and wires. New cats.
Dyno results:
A/F = 12.6 @ 3800 RPM
A/F = 13.0 @ 4600
peak hp = 243
peak torque = 275
Mustang dyno
I expected atleast 300 HP at rear wheels. What to check?
torque converter lock up
knock sensor
fuel pressure
throttle body open
Dyno service out to lunch?
Any comments or help appreciated.
JA
Old Jan 7, 2006 | 01:11 AM
LookinAtMyPlate's Avatar
yea im gonna say dyno service was out to lunch thats crazy. sometimes ive noticed dynos are just way off my friend has a 97 kennebell cobra and it dynoed at 300 to the wheels so go up there and tell them there strait up wrong haha
Old Jan 7, 2006 | 11:05 AM
89rsragtop's Avatar
Something wrong with that dyno. Ask them what other LS1 are running on their dyno.
Old Jan 8, 2006 | 12:18 AM
JGA's Avatar
JGA
Hi
Thanks. I will try and find anouther dyno service. Atleast I know my A/F is OK. I have a Vinci tuner and tried to tune it, but it could not interface properly with the PCM code. I have sent it back for reprogramming. Hopfully I can get it back and get it to work.
Thanks JA
Old Jan 8, 2006 | 11:38 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Mustang dynoes read lower numbers, typically, but serve well for tuning.
Try a dynojet next time if you want dyno war numbers.
Old Jan 8, 2006 | 02:16 PM
JGA's Avatar
JGA
Thanks
JA
Old Jan 8, 2006 | 07:56 PM
Slowhawk's Avatar
LS1Tech Sponsor
But they will if they are set up right.Some Mustang dyno's have been set to read in line of Dynojet's.
For a 98 car I would check the KR.It is common for 98's to pull 3.9 degree's of KR for no reasion.
Old Jan 8, 2006 | 08:08 PM
JGA's Avatar
JGA
Hi
Would the fix be a new KR sensor or a software patch? Thanks for the input.
JA
Old Jan 8, 2006 | 09:37 PM
Slowhawk's Avatar
LS1Tech Sponsor
First you need to scan a pull and see if it is actually pulling KR..Alot of the 98's I actually just delete the sensors when I get the tuning set.Keep in mind the tuning has to be spot on to do this or you risk wrecking the motor.
Old Jan 8, 2006 | 10:44 PM
JGA's Avatar
JGA
Hi
Yes that will be my next task. Get a scanner and do some logging. Thanks for the help.
JA
