Stock Dyno run on a 2001 SS m6?
Different dyno's derive bhp different, thus you will see a lot of different numbers for power. There are also different standards and correction factors also which only make it more confusing.
If you car is running good then it should make 290-300rwhp on a Mustang Dyno or similar corrected to SAE.
On a DynoJet Dyno you are more likely to see 300-310rwhp, and maybe even as high as 320rwhp if it's STD and not SAE. This is because a Dynojet is a non load bearing dyno and works differently to load bearing dynos like the Mustang dyno.
So don't worry too much about the actual number. 292rwhp on a Mustang Dyno is more impressive than 305rwhp on a Dynojet.
Post back you results, mind.
Well assuming when you say stock you actually mean STOCK, lol.
Also the dyno numbers will vary from day to day. The weather is a factor, even though the Dyno is supposed to correct for hot humid days it will still show less.
Tire pressure is another subject, make sure your tires are inflated correctly.
Peace,
Craig.
Thank you for the info...so i know it might vary in diferent dyno but it's in between 290-315hp...
from now on!BUT I WILL ADD: I dream of having a newer prelude (like yours) for my daily commuter, and my camaro in my garage to wipe with diapers every night, and drive on those mostly sunny Sunday mornings!!! We are on the same boat I think
..RWD onws me lol... n yea i kinda wish i could keep it for daily but i cant soo...gots to go...bring in the SS
n we r in the same boat...
before you actually drive it
