408ci redynoed and tuned!!!
My friend blue SS we gained 18hp up top and 25ft/lbs.We just took fuel away as it was rich in our baseline at 12.1afr.Leaned her to a good 13.3 18hp and 20ft/lbs,took away 2 degrees of timing down to 25degr no luck but little bit rich at 12.9 added more back the timng Same hp but 5ft/lbs more.We ended up with 398hp and 375tq.Increase of 18hp and 25ft/lbs,all with converter unlocked,car idles way better,very smooth.
Overall wasnt bad at all as a ameture tuner, did a good job!!All keep u all posted tonight!!!!
For what it's worth, 6000 rpm is probably too high of a coupling point for your combination. Sounds like your engine torque is blowing right through your converter. Might be time to examine your stall.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Nice results!!! I had my original tune done by HPE also, but when I got to a local dyno I had the same problem, i was lean around 14.5 got my HP tuner dialed in the AF and messed with the timming and picked quite a bit of power. Dont know if its thier AF meter thats off or if its a altitude/weather issue between Houston and where I live. Anyhow nice #'s.
www.modernstreetperformance.com
that is where we had the cars re-dynoed at
p.s. dmoney likes men
From what I have read, it seems that Chuck doesn't want to purchase new sensors for his Wideband, so he uses other methods to calcuate the AF.
duh. Im glad to see you got your car putting down some good numbers, even after it was tuned by a proffesional. Good luck with the stall.
