Trex Dyno Numbers Are In!!!!
Old Mar 1, 2006 | 01:33 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Doesn't seem like anyone here is taking into account that NLP's dyno is known to be really stingy. Unless something has changed...
Old Mar 1, 2006 | 10:45 PM
2002blkss's Avatar
Default dyno graph
heres the graph!!
Old Mar 1, 2006 | 10:51 PM
slowpoke96z28's Avatar
wow. the power was already starting to fall off by 6500. doesn't look like valve float or an ignition hardware fault either. what size are those flowtech headers?
Old Mar 1, 2006 | 10:59 PM
CamTom12's Avatar
starts to fall at 6, really...
That is kinda odd
Old Mar 1, 2006 | 11:03 PM
2002blkss's Avatar
the headers are 1 3/4 basically trhe same as hooker
Old Mar 1, 2006 | 11:10 PM
yoou could probably use bigger header primaries. this dyno graph is post-tune?
Old Mar 1, 2006 | 11:14 PM
2002blkss's Avatar
yea the graph is after tuning but i think im going to go back and see if there is anything else we can do to try na dget the numbers up i threw a code for fuel air metering so i will be going in to check that too.
Old Mar 2, 2006 | 12:48 AM
SlickVert's Avatar
Looks good.
You need to flatten out your AFR line, it went rich right after 6,400 rpm.
I do like how it started kicking after 4,500.
At 6500 it looks like it is making more then 60hp more then you had, and at 7,000 more then 90 hp.
What was your WOT timing set at in the higher RPM?
Did you try adding timing to see what it liked?
I think it should be 29 to 30
What size is the Y and cat back?
Old Mar 2, 2006 | 12:49 AM
FstBlkz28's Avatar
1 3/4 primaries should be fine for a stock-headed car. But all things taken into account:
4.10 gears ~8-10rwhp
Dyno reads low (Or rumor has it)
and the absence of the UD pulley which most full bolton cars have.
I'd say that your numbers aren't that far off from what they should be. Run'er at the track and see what she does.
Old Mar 2, 2006 | 05:53 AM
IrateTA's Avatar
Originally Posted by blkZ28spt
...don't you know I'm psychic?
Heh, I remember lauging when you posted that, but dam
Old Mar 2, 2006 | 06:37 AM
99FormulaM6's Avatar
i dont like that at all.
you have no power down low, and dont start making until 5k+ rpms. theres only like 330 rwhp at 5k. thats no fun
Old Mar 2, 2006 | 07:58 AM
  #32
BAIN's Avatar
I don't know about a manual, but with an auto, 4800 stall, and 4.30 gear it's all the fun you need
Old Mar 2, 2006 | 04:39 PM
  #33
2002blkss's Avatar
yea timing is at 28 and the y-pipe is 3 in" im going to see if he can work on the idle a little more and the a/f
Old Mar 2, 2006 | 05:54 PM
  #34
SlickVert's Avatar
Try taking the timing to 30, that cam is a big compression bleeder. I bet if you poll most that put down good numbers with that cam they are running 30 degrees and open headers.
Add some time timing and see how it reacts, then take it to the track.
Old Mar 2, 2006 | 06:00 PM
  #35
why would open headers help? i dont know what exhaust hes running now, but that cam peaks really high, and makes all the power up top, but running open headers shifts the power band, so he wouldnt have much power down low if he did that
Old Mar 2, 2006 | 10:21 PM
  #36
eamador11's Avatar
New 4.10s? dont you have to break them in before wot? oh well, nothin like breaking them in the hard way! lol
ps- numbers are right on for cam only. put the a/f at 12.8 fo rbest N/A performance
Old Mar 2, 2006 | 11:32 PM
  #37
2002blkss's Avatar
yea gears have been in for a while they are well brokin in
Old Mar 3, 2006 | 02:01 AM
  #38
DanZ28's Avatar
I'm more curious as to why you only gained 15 RWTQ? I agree it's running to lean as well, try messing with your AFR more on the dyno and see how your numbers work out. From previous dyno to this one the results are not that bad though.
I just pulled my Trex out and put a much smaller custom grind in, wanna bet on which one does better? ..
Dan
Old Mar 3, 2006 | 08:37 AM
  #39
BAIN's Avatar
As in?...... Dyno #'s or track times? Also are you really going to post the results if the T-Rex is better?? Good luck either way
Old Mar 3, 2006 | 03:04 PM
  #40
Josh's Avatar
Originally Posted by DanZ28
II just pulled my Trex out and put a much smaller custom grind in, wanna bet on which one does better? .
Please let us know. I was considering doing the same, but after some research, it didn't look like it would be worth the time and money.
Josh
