ETP 215* H/C results - Pictures
These are the preliminary results. I have some valve instability around 6300 rpm and then it gets bad after 6500 rpm. It's probably costing me some peak power. It looks like I should have shimed the valve springs. This cam should pull all the way up to 6800 with no problem and the torque comes on early with 344.6 at 2600 rpm. These results are with a stock pulley, water pump, through the cats, and a crappy Vararam foam filter.
STD
![](http://i1.tinypic.com/sevzif.jpg)
SAE Comparison when I brought the car in for a baseline before the h/c install. My old setup was a 225/225 113 lsa.
![](http://i1.tinypic.com/sewojq.jpg)
I have another graph with a higher peak hp but lower tq.
STD
!LS1 11 Second Club
Very nice. Very nice. Get those springs under control and you've got a killer setup.
Very nice peak tq figure. Congrats.
So, you've got a 224/234 cam with .637 lift? Is that an LSK grind on the intake?
It's basically a 224 LSK intake lobe and a XER 236 exhaust lobe on a 115 lsa retarded 2 degrees. The heads have a 62cc chamber and I used a stock mls gasket.
I'm going to get a better filter, remove the cats, add a pulley, shim the springs, and see what it will make then.
Originally Posted by waterbug1999
Did you have to use longer pushrods? I have read around a 8.1 and some vendors are telling me the 7.4's would work. Im just curious as I am looking at these heads as well. Just trying to get the facts straight. Whats you CR?
LS1 Tech Administrator
Gotta love those LSK lobes. Great power everywhere!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by CNB
What's your setup?
Originally Posted by 8banger
Nothing as great as this, but a slightly larger LSK cam, the Thunder TRak (233/235, .648"/.598", 112), stock heads for the next few months (then I'm upgrading to PRC's), FULL bolt-ons, 3800 stall, and 3.73's
