LS2 402 Way Low Dyno Numbers. Help Please!
#83
Flat top pistons and 72cc heads milled to 65cc. Should yield about a 11:1 compression. I checked the heads to make sure that they were milled by getting some 72cc head dimensions from Tony Mamo.
Patrick, I thought that you said that this is about what I should be seeing.
#84
#87
Here are my guts:
4.000" Eagle 4340 forged steel crankshaft, balanced to rotating assembly
4.000" Ross 2618 forged alloy pistons with -6.00cc dish (includes new rings and full-float pins)
11:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
6.125" Eagle H-beam rods
Intake flow up to 304 CFM at .500 lift, 320 CFM at .600 lift @ 28” of H2O.
Exhaust flow up to 250 CFM at .600 lift @ 28” of H2O (using 1-7/8 inch exhaust pipe).
AFR 225cc heads with 65cc combustion chamber.
CNC ported intake and exhaust ports, and combustion chambers.
2.080 intake, 1.600 exhaust standard length valves.
3-angle radiused valve job.
7° titanium retainers and valve locks.
1.290 inch double springs, 135 lbs seat, .600 inch maximum lift.
.596”/250º int. .596”/246º exh. camshaft.
#88
Whoa, whoa, guys. I too have 42#ers in my 402 but I am not ready to say that is what is causing the problem until I see a log that shows the injectors hitting 100% duty cycle at say 3500 rpm which is where this motor starts laying down.
And I will bet that they are not locked open at 3500 rpm. So there is something else going on. The 42s will be a nice addition but I have never hit over 60% DC with mine so that is probably not the biggest problem. (I am at 384 rwhp/344 rwtq with a smaller cam than this, but probably better heads).
And was the cam degreed when it was moved one tooth???
BTW, the leakdown test is really not at all hard to do, but you do need the leakdown kit and the compressor. But once you get the sparkplug out, you can work on the degreeing also.
Perry
Perry
#89
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#90
You better run a CR calculator on that. No wonder it is detonating.
Perry
#91
Originally Posted by NEVRLIFT
I hope those numbers are 4xx instead of what you posted. I will assume that it was a typo. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
And that is what comes by having a couple of LT1 383s also. You forget how much power our cars make.
Perry
#92
If you are running a Cometic 0.051 gasket and truly have flat tops at 0.008 out of the cylinder you are running 12.13:1 CR with 65 cc heads.
If you have a thinner gasket (very possible) you are well above 12:1.
Try a tank of race gas and redyno and see what happens.
Perry
Perry
#94
Guys,
I have the same block-head combo as CobraKiller and I do not have any detonation even on the 91 octane fuel we have in Kalifornia. And I still don't believe stock injector size is a problem at anything under 5500rpm with this motor. I made 400# of torque at 2500 rpm, 490# by 5000rpm. CobraKiller isn't there yet. But he will, and then some!
Chuck
p.s. I may be off base considering I am comparing my stock LS6 injectors against whatever ones CobraKiller may be using. Stock LS1 injectors would probably cause the motor to fall flat on its face well before the 5,000 rpm range.
Chuck
#96
... but there's gotta be something else.
Chuck
#98
Originally Posted by Chuck Harmon
Guys,
Chuck
Chuck
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#99
Have you checked your Hydrosilator? I saw a special a couple years ago about when cars go bad. The Hydrolsilator, a little know device installed in every car starting with those made by Henry Ford can cause very bad things to happen. You may find more information under the topic "pogoe carburation-injection systems"
Chuck
Chuck
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
