Dart 205 Results
Removed:
Stock lifters
Crane 1.8 rocker arms
Installed:
Morel lifters
Crane 1.7 rocker arms
Dart 205 heads
Here are the results. I picked up about 24 hp and 24 lb-ft of torque. I also eliminated my infamous dip at 5,800 RPM. The other interesting thing that I ran into was tuning issues and the car was stuck at 385 hp. It turned out to be a dirty K&N filter in my Vararam
Shame on me, I forgot to clean it prior to going to the tuning session. Also worth noting is that the prior dyno was last November and the interesting thing here is the fuel situation. With the conversion from MTBE to ethenol in the fuel, I'm not sure how much that affected the final results but a lot of you guys who have done mods over the winter may find this skews your final results as well. I tried to buy 'non-ethenol" fuel, but apparently I didn't. Slowhawk who did the tuning (great job again
) noted he couldn't put in as much timing due to the fuel.
i'll change the mild VHP 062 camshaft in my buddy's 99 SS to VHP 060 camshaft then hit the dyno again to see how it works !!!
peace
Steve
Did you have stock heads beforehand?
I am also curious how much this new gas with the ethanol is costing on the dyno
So it might help if you have real high compression, but Id try not to use it otherwise.
I guess the best way is to dyno the differences. (Hmm maybe something will come up on google)
Since the state is so small, wonder if the neighboring states made the same bonehead decision.
Congrat's on the Dart's. Was it their CNC'd heads they supposedly were gonna' come out with or have they not started CNC machining them yet? IMO, you've prob got a few more numbers left in there. Dart makes great heads for the price from what I've read and seen here. Ported right, they have put down some good numbers.
Yeah this winter fuel is screwing up a lot of my friends #'s, I'd be happy w/ 400 through your setup, good job.
, then it just keeps on going up nice and smooth.
