Wheel HP vs. track performance?
Old Apr 30, 2006 | 07:21 PM
Nsty98LS1's Avatar
just put down 365rwhp on a dynojet, my raceweight is 3640, car went 12.003 at 113mph
Old Apr 30, 2006 | 07:34 PM
REDSS01's Avatar
410whp 392wtq
11.6@120mph MT dr's
12.0@118mph street tires
F13/ Stock LS2 heads
12 bolt/ 3.90 gears
3580# RW
Old Apr 30, 2006 | 07:58 PM
NOS327's Avatar
Thansk guys, keep it coming. It's updated again.
Looks like there's a pretty big deviation at about .12 hp/lb or 8.2lb/hp with that low point being 109mph and that high one at 118. Anyway, keep it coming. That trend line equation still says that a 400rwhp 3600lb car should go 115.03. Seems right.
Old Apr 30, 2006 | 11:37 PM
2c5s's Avatar
99c5 a4 393rwhp 11.78 @ 117
Old May 1, 2006 | 12:08 AM
Phlip00WS6's Avatar
SOB! Somthings gotta be wrong.. I checked and I have 0 degrees of KR. What am I doing wrong.. I'm power shifting the 1-2 and the 3-4.. On the street I can race a car puttin down the same amount of power as me and be right beside em or pull em by a car.. so somthing is going on just at the track... what else could it be. My clutch has been a POS since I had it installed.. it shakes the whole damn car and makes the torque arm come loose, could it be causing the BS? Thanks for any info!
Old May 1, 2006 | 12:14 AM
WS6 #3392's Avatar
Times are in sig. Weight is 3745 lbs. That is with me in the car.
Old May 1, 2006 | 04:46 PM
Viper's Avatar
12.4 @119
3600 weight, lousy 60 ft! Bald Nitto RII's.
Old May 1, 2006 | 05:05 PM
LostCauseZ06's Avatar
hrmm.. chart seems flawed??? i plan on being around 800 RWHP with a 2900 lb race weight.. that comes out at a .25 power/weight ratio.... which is a 150 trap speed... :X dont think ill be anywhere near that fast..
Old May 1, 2006 | 05:26 PM
98LS-WON's Avatar
I'm thinking it will start to curve at the faster end of the chart v/s staying linear. I am now officially intrigued. For ***** and grins, does a top fueler graph somewhere near the established line.
Old May 1, 2006 | 07:25 PM
NOS327's Avatar
I was actually thinking about graphing some higher end cars. I know a couple guys in Omaha that have made 1100rwhp and go 8.0s @ 170ish. There is definitely something to the law of diminishing returns though, so yeah it will have to lay down, but I think from 100-130mph it should be pretty close. 8000hp fuel car would have to go over 1000mph for my stuff to fit, definitely not right. I may be able to fit a pro-stocker on the curve if I knew some actual info.
LostCause, a friend of mine from Bowling Green KY made just 701 at the wheels in a 3000lb 4-link camaro that's been 9.30s @ 145mph. I don't think it's flawed where you think you are going. Also, think about the 185hp Hyabusas that go 150mph at 750ish pounds (480lbs dry + fuel + 200lb rider and leathers). .25hp/lb = 150mph.
Old May 1, 2006 | 07:31 PM
97blkz's Avatar
you just described my car!
Old May 1, 2006 | 08:00 PM
  #32
Ryne @ CMS's Avatar
LS1TECH Sponsor
approx. 3500 lb vette, 550 rwhp 501 rwtq, 10.85 @ 129.45 DA 2100 ft.
Old May 1, 2006 | 08:06 PM
  #33
Chris81's Avatar
12.18 @ 113.41
Mods in sig.
The car made 364 rwhp on a Dynojet and weighs about 3600 lbs.
Corrected from the nasty DA to 11.64 @ 118.68 using the NHRA correction factors.. for comparsion only.
Old May 1, 2006 | 08:17 PM
  #34
NOS327's Avatar
2c5s I put you at 3218lbs since that's what I found for those vettes. Is it different than that?
Old May 1, 2006 | 08:45 PM
  #35
how in the hell is your car that heavy? stereo?? wheels??
mine weighed in at 3275 on the scale with me in it
Old May 1, 2006 | 08:50 PM
  #36
NOS327's Avatar
..guys in Omaha that have made 1100rwhp and go 8.0s @ 170ish.
Hey it kept the equation close enough for my liking. Maybe this will be good from 105 to 175mph.
Here's a clip of his car. Yeah, it's a mustang, but it sure spanks my azz, so I'll let him in my data pool.
http://inductionweb.com/UndrPrsr2.mpg
Old May 1, 2006 | 09:07 PM
  #37
Black8Banger's Avatar
476hp 521 tq
10.4x @ 129.8x in the 1/4
Old May 1, 2006 | 09:41 PM
  #38
Ryne @ CMS's Avatar
LS1TECH Sponsor
me 220 lbs, stereo around 100 lbs, 5 point roll bar 80 lbs, Iron block around an extra 100 lbs.
it might weigh less, but thats what i figured.
Old May 2, 2006 | 12:08 AM
  #39
oh i see iron block extra 100 lbs??? my entire assembled shortblock with engine shipping stand only weighed 375 lbs.. that is exact weight based on the shipping statement. i dunno how much an aluminum LS1 shortblock weighs??
Old May 2, 2006 | 06:22 PM
  #40
NOS327's Avatar
Black8Banger, what does your car weigh? I stuck you in at the usual 3600lbs since you didn't specify and you are by far the most deviant from the trendline. See that one sticking way up at .13HP/lb, that's you. Hopefully (for my graph's sake) that thing weighs somewhere down around 3300lbs. On the other hand, you'd really be putting a hurting on these guys if you went 129.8mph at 3600lbs and only 476whp.
