Very Dissapointed with dyno results today...
Old 06-10-2006, 04:02 PM
  #161
UltraZLS1's Avatar
At the crank they are good for probably 450-460...but not at the wheels. 28lb injectors with 450rwhp (over 500 at the motor)would be well over 100% duty cycle. And < 80% is considered the safe zone
Old 12-28-2006, 10:31 AM
  #162
jeffstar's Avatar
So, what ever happend with this guys motor/combo?
Old 12-28-2006, 01:48 PM
  #163
Bader-X's Avatar
I`m interrested also .... all I can think of is a maf or a sensor like the tps or something else screwing his numbers .... you service engine soon i on? or its lamp is fused maybe? no codes what so ever?
Old 12-28-2006, 03:03 PM
  #164
jeffstar's Avatar
Well, the poor guy doesn't have any tuning software so he's almost helpless beyond basic stuff. Really sucks for him. I guess I'm just curious.
Old 12-28-2006, 06:18 PM
  #165
joshp14's Avatar
That poor guy (me) hasnt found anything wrong. 'm still running the stock injectors on my mail order tune. As soon as I get the money, I plan on adding a 90/90 setup with injectors and a dyno tune. Hopefully this combo will get me up to the 450-460 mark. I have ZERO codes, car runs good and strong, plenty of power, just the dyno numbers arent the greatest. I'm open to any other suggestions you all may have.
Old 12-28-2006, 06:37 PM
  #166
Grimes's Avatar
didn't go through the entire thread, but have you tried to see if you have anything obstructing your exhaust flow - like broken up cat pieces in the y-pipe?
Old 12-28-2006, 06:50 PM
  #167
jeffstar's Avatar
http://motors.search.ebay.com/_W0QQsassZdeatschwerks
Good place to get injectors. They come flow matched with a flow sheet. I'm running them with good results.
Old 12-28-2006, 08:15 PM
  #168
MNR-0's Avatar
Tried dumping the pipes and dyno with open headers?
Old 12-29-2006, 06:06 PM
  #169
joshp14's Avatar
The dyno was with gmmg catback and jet hot catted y-pipe...if you call them cats, more like rasp reducers. If you have clogged exhaust you can usually tell just by driving....but no I havent visually looked in the y-pipe.
Old 12-29-2006, 11:27 PM
  #170
Grimes's Avatar
I would honestly check...seems like you have eliminated most of the other things!
Old 12-30-2006, 09:10 AM
  #171
Old Geezer's Avatar
Question
Had same problem w/ a turbo Puick, v-sicks.... Lazy, low on pwr.
Chased all I could think of, except for the air cleaner.
Depending on the size, it could be a serious restriction. I built a dual cleaner/plenum system.. Picked ALOT of rpm, and HP.
What size is the cleaner?
Has the engine been run with it off?
Old 12-30-2006, 09:48 AM
  #172
cablebandit's Avatar
why are you running such a cold plug? if the afrs can run leaner and more timing, i'd think a stock plug would be cold enuff...maybe one step colder but nothing along the lines of a "tr-8"
Old 12-30-2006, 09:53 AM
  #173
Administrator
unit213's Avatar
What plug is he running? A Tr55 should be fine for that kind of power
I would think. Well, the power that his mods should make.
I'm only running a TR6 and my car sees 19psi daily.
What % duty cycle are the stock injectors at?
Old 12-30-2006, 03:31 PM
  #174
joshp14's Avatar
I havent check the DC of the injectors...I imagnie they are maxed out or at least 80%. I'm runnng a TR6 plug because I'm running 11.4 compression. As far as intake, just a holley air filter, slp lid, bellow, stock MAF, stock TB smoothed out, stock LS6 intake.
Old 12-30-2006, 03:32 PM
  #175
joshp14's Avatar
Where did TR8 come from??? I'm running the TR6's.
Old 12-30-2006, 03:39 PM
  #176
Spellbound's Avatar
Originally Posted by Patrick G
To me, it looks like your throttle body is not opening up all the way. Basically, you start showing the gains down low, then they go away. I know it sounds too easy to miss, but I've seen Stock Eliminator guys miss this before. Check the throttle cable and have someone step on the throttle and see if you're getting 100% throttle opening.
Had this happen on my girlfriends car one time....the cable was hooked to the wrong spot on the NW TB, lol made about a 25 rwhp diff.
Old 12-30-2006, 04:42 PM
  #177
Old Geezer's Avatar
Question What are the..
dimensions of the filter?
L x W x H ???
It's fairly easy to calculate the air requirements, and the capacity of the filter, to determine if it's a problem..
Old 12-30-2006, 04:45 PM
  #178
joshp14's Avatar
Air filter is whatever the stock ls1 filter is.... 16" x 8" x 1.5"
Old 01-01-2007, 03:27 PM
  #179
i dunno WHERE i got tr8 from...sorry...carry on
Old 01-01-2007, 11:27 PM
  #180
csmc711's Avatar
hmmm, perplexing in the least
Quick Reply: Very Dissapointed with dyno results today...
