power from heads
i dynoed 385rwhp with an f14, fast 90, nw90mm tb, QTP LT's, no cats, pulley, elec. water pump, fipk, *stock ported heads with bigger valves*, 12 bolt rear.
i know these #,s are real low but recently have been coming to the conclution that i probably got scammed on my heads
. if that is the case how many hp could i be leaving on the table with stock heads and what would i be looking at gaining with a set of Dart heads.
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
Check out this post right here for some info how my car did with Dart heads. I also had bolt ons and the F14 cam.
https://ls1tech.com/forums/dynamometer-results-comparisons/480231-dart-205-dyno-numbers.html
Originally Posted by cash50
even with stock heads, with like every bolt on except maybe a/c delete you should be making like 430 easy. maybe your injectors are maxed out??? or the tune is bad?? something seems funny about those #s
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Super Hulk Smash
If the heads were ported improperly, I could see you losing 20rwhp from that. Try slapping some PRC LS6 heads on there and see what happens. Also, check to make sure your compression is good. Perhaps the port opened up the chambers quite a bit and you've lost some compression.
Otherwise, 385rwhp seems low for even an F14 with a ported LS6 intake and stock LS1 heads. That should be close to 405rwhp. Add in a FAST 90, mildly ported heads (should be at least as good as LS6 heads), EWP, and the F14, and I'd expect 430rwhp pretty easily. Just stock LS1 heads with the FAST 90 and F14 should be around 415rwhp.
LS1Tech Premium Sponsor
Do you have data on what the heads flowed?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Super Hulk Smash
if i were to get a set of Dart,s ( or even stage III patriots)and slapped them on would i see 420rwhp?
I’d recommending calling Allan @ FMS.
Talk with him and look at a balance approach to your set-up.
He will be best to help you meet your goals as you already have his cam.
Good flowing heads, compression and match camshaft are only a few key points to having a balance set-up.
Good luck,
Bob
Good luck,
Bob
the budget stage 1 ported 243s are a great value right now.with them and your mods 420 should be very reachable.maybe a .015-.020 haircut or a thinner gasket and 430 + if no p/v clearance problems anyway.
