Uh, tq peaks around 3100 and picking up 3-4 deg KR till 5k...
LS1Tech Sponsor
Your 408 probly doesn't like timing.An efficient stroker motor will always run less timing than a 346.
I have a similar motor setup to your's. Midrange timing is 16 degree's and it tops out at 20 degree's.Car made 530hp/490tq to the tires.
Quench,Cam timing,exhaust,cubic inch and intake dictate the timing an engine needs
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Quench,Cam timing,exhaust,cubic inch and intake dictate the timing an engine needs![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Update: Retarded the cam back to straight up and isn't pulling as much KR now, but still showing some. Picked up hp/tq everywhere with a peak gain of 25hp and 10ft/lb tq over the last pull with the cam advanced 4*. Gonna try and put some race gas in and see if the knock goes away. Other than that, don't know what else to do other than pick up some new knock sensors and see if that fixes it.
I certainly think something fishy is going on right now because my quench is perfect, running a 160 tstat, and it's not even really THAT hot out. I'm leaning towards my knock sensors may be going since they are the original ones from my stock 346 that were then transferred to a 370 that blew up on the dyno and then onto my 408 now.
#32
7 Second Club
Well a big bore will require a slightly different timing table, if you can have your tuner send the file over my way so we can check out both on both sides.
Phil
prostreetmotorsports@comcast.net
Phil
