How far off are my dyno #s?
Old Sep 2, 2006 | 11:45 PM
anLS1x2's Avatar
I don't have a choice on switching cams, so what do I need to do to get my horsepower up? Should I port the heads?
Old Apr 20, 2007 | 02:55 AM
maxxxboost's Avatar
if i were you, for now i would raise the compression ratio by getting .03 head gasket and/ or mill the heads . make sure you do your math when calculating compression ratio you should have around 11.5-11.8 after that check your piston to valve clearance.
