stock engine dyno charts - LS1 and 02+ LS6
Old 08-23-2006 | 11:44 AM
FastKat's Avatar
Default stock engine dyno charts - LS1 and 02+ LS6
Does anyone have engine dyno charts of a stock 98 – 2000 LS1 and a stock 02+ LS6? I’m trying to isolate the differences between the stock LS1 cam from the 98-2000 F-Body and the 02+ LS6 cam. I would rather see an engine dyno chart because you’re not seeing effects from converters and driveline loss.
Thanks, -Dave
Old 08-23-2006 | 11:52 AM
warp10's Avatar
2000 M6 Firehawk with a lid only at that time. (Not engine Dyno but that's all I got)
Old 08-23-2006 | 12:02 PM
camaro98z28's Avatar
This would be cool to see. I thought they were all rated about the same. 345HP?
Old 08-24-2006 | 10:24 AM
FastKat's Avatar
Anybody with a stock Z06 dyno chart? Prefer an engine dyno sheet but a rear wheel dyno through a manual would work too.
Old 08-24-2006 | 01:32 PM
DramaFoYoMama's Avatar
How can you isolate the cam when there are two variables involved? When doing an experiment, you change one variable at a time. Did you forget about the heads?
Old 08-24-2006 | 10:03 PM
DrkPhx's Avatar
I found the original GM dyno comparisons.
1) LT5 vs LS1 vs 01 LS6
http://www.idavette.net/hib/ls6/imag...vs%2090LT5.PDF
2) 01 LS6 vs 02 LS6
http://www.idavette.net/hib/02ls6/photos/43102b.jpg
Excellent overall info on the LS6.
http://www.idavette.net/hib/02ls6/index.htm
http://www.idavette.net/hib/ls6/index.htm
Old 08-24-2006 | 11:44 PM
98camaroLS1M6's Avatar
nice comparisons!
Old 08-25-2006 | 11:29 AM
FastKat's Avatar
No, I remembered the heads... the valve size and CR are different, however I didn't think they would have much of an impact on the lower RPM numbers... if anything I think the smaller valves would help the low end but I don't think it will make much of a difference. I would like to see an exact comparison but I'll take what I can get! I think a torque converter and driveline loss can skew your results more than the heads.
Old 08-25-2006 | 01:08 PM
FastKat's Avatar
That is some good info... thanks! I think I will be taking the 02+ LS6 cam after all.... besides, my heads already have the larger valves.
Originally Posted by DrkPhx
Old 08-26-2006 | 01:19 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
I have my dynos (rear wheel) if you need them from a z06.
Old 08-28-2006 | 12:21 AM
Frost's Avatar
the runners are different too though right?
Quick Reply: stock engine dyno charts - LS1 and 02+ LS6
