Very Low Dyno Numbers
Thanks,
Matt
(Do a search....answer is alot). IMO its better to put a little more lift in the lobe and run a lower ratio rocker but of course you will get varied opinions on that (as well as just about everything else).
I touched on this with you already on the GTO board in addition to the fact different dynos yield different numbers.
Humor me and swap back to your stockers and pay attention to the proper pushrod length as well. Also I wish you were running our 8019 springs which I have done ALOT of testing proving out on the dyno and am convinced are the best springs from a valvefloat/power producing perspective. Nothing has shown me better results and Ive tested quite a few different valve spring combinations.
Show these guys the gragh overlays as well (even though different dyno). The area under the curve gains are substantial and they can also see how the power goes flat from 5500 on (telltale signs of valve control related issues).
Tony M.
