View Poll Results: You RWTQ
430-434
44
44.90%
435-439
8
8.16%
440-444
9
9.18%
445-449
6
6.12%
450-454
8
8.16%
455+
23
23.47%
Voters: 98. You may not vote on this poll
Highest torque from stock 346 (NA) on pump gas?? Post up if you make 430+
Originally Posted by offaxis
Lets be honest here. there are alot of Bs dyno numbers on this board.
I agree with the above statement. We race at many different tracks, none are faster than the other. On my dyno in a auto car 450 traps 128, 420 traps 125-126 in a 3600 lb car that works right, its a pretty consistant thing.
DA pretty much evens the playing field its pretty close when you correct to zero DA
I don't know where you get this 450RWHP is supposed to trap 127 or 128 because down here in mississippi with 500-550RWHP @3600 lbs will net you 127-131MPH and 400RWHP-420RWHP will net you 115-118 in a 3600 lb car.
1 Post
Back on topic, let's see some more high horsepower/torque H/C NA #'s.
Originally Posted by Louie83
Amazing set-up. Very well thought out.
What rear is that through?
The drivetrain is OEM except the clutch for obvious reasons.
Stock MN12
Stock Differential
Stock tire size 295/35/18 mounted on OEM rims. (to change soon now!!!)
Thank you for the compliment...
Christian
Vengeance Racing recently made 521/464 through my 03 ZO6.Here's the link.https://ls1tech.com/forums/dynamometer-results-comparisons/661579-trickflow-vengeance-racing-521-464-dyno-graph-inside.html
#32
Originally Posted by hunterdawgs
Vengeance Racing recently made 521/464 through my 03 ZO6.Here's the link.https://ls1tech.com/forums/showthread.php?t=661579
#33
Originally Posted by WS6FirebirdTA00
Yeah but thats questionable IMO and others. The cylinder pressure required to make that torque, you would need to run race gas. Things just dont add up in that combo to beable to do that on a 346" motor.
#34
Question the results all you want.... Thats typical... People have always questioned shops when they take things to the next level.... It has happened with Cartek, LG, Futral.... now it is our turn.... Funny thing is, we arent the only ones making these #s.... We made a whopping 15 more ftlbs than a home built combination and our #s are questioned.... LOL
The results will speak for themselves.....
Ron
Ron
#35
Originally Posted by lilbuddy1587
I think he means to say that 450= 127-128 in HIS area. The air quality, gas, DA all effect performance and it varies widely across the US. I watched my brothers X4 cam only car trap 121 and some change but yet the car only put down 422/371(ls6 intake, typical bolt ons) which is unusual for shitty AZ conditions. How? Luckily got a decent DA, gears and a proper suspension in a car that weighs 35-3600lbs. So again, there's always a lot of different variables.
So 450 on his would be 480-490 on most dynojets.
We race at more than 1 track and more than 1 area.
my car ran within .1 from our local track in MD. to the track in Memphis
Ron@vengence I call BS until any of those 500hp monsters run mid 10's@130
#36
Thats understandable.... Ill call BS on your mid 9s in street trim until I see it in some Ga air
Originally Posted by ATVracr
GrannySS has a mustang dyno and it seems to be a little on the low side to most other dyno's I've seen.
#39
Originally Posted by Ron@Vengeance
Yea, I watched the video... About 50 60ft passes and one shot of the entire 1/4 Most be a one shot wonder
Ya must be
2,500lbs dynojet rollers are much easier on cars
Try keeping the weather station on your dyno jet away from the bullet heater
#40
