518rwhp Heads and cam
PRC Stage 1 Heads w/ LS6 valves
Custom Camshaft
Custom Vacuum Pump Setup
STOCK Bottom End with Stock Rod Bolts
Moser 9" with 4.56 Gears
MT Drags 28X10.5X15
Beck sheetmetal Intake Manifold
We will be at HRP tomorrow night testing our new times.
Stock bottom end and 7800rpm?!
You're my hero. 518 rwhp !!!!!!! Too bad you didn't get above 400 on the TQ side.
Stock bottom end, how did this happen and not spin a bearing??
Living on the edge, good luck and SWEEEEEEEEET numbers.
You got everyone so curious. That is the strongest N/A LS1 I have seen.
Compression ratio?
Compression ratio?
