Corn Powered Corvettes!!!
What were your results
JEFF
__________________
We only got two passes in on fri night, and they've only been to the track once this year. The White C5 w/ the 150 shot went ?11.40 @ 131 on his only pass, the 427 camaro went 11.5x @ ?127? on his 2nd pass. I don't recall the other times, but they may post them up. We got rained out the rest of the weekend. These were all on drag radials. It sucked because the track seemed pretty decent, but a guy needs more than a pass or two when you do it once a year!
andy
e85 is far from the 'end-all' or answer to oil importation. US agriculture can NOT produce even 10% of the E85 required to fuel the US. using corn based anyway, other crops can produce much more gal/acre, but still fall way short. but that is a whole nother nopic.
I am in agreement as far as your concern with the oil importation issue. E85 can be made from switch grass and many other items. Brazil and many other countries have been using it for 20+ years, the US needs to do something to become less reliant on importation- I think we can all agree upon that. But from a hot rodders standpoint, it is an efficient alternative for race gas and it's available at the pump.
well that is very incouraging. will it also then compete with 'lean cruise' on with regular gas? ls1s have reported well into the 30mpg range using it. is there the same 'lean cruise' capability with E85?
if you all want to keep up on e85 and get active join the coalition! www.e85fuel.com
the issue with the 30% decrease in fuel mileage that everyone reports is b/c flex fuel vehicles are usually trucks/passenger vehicles. this means they not only have to be able to run the e85, they also run on **** water (regular 85)... if a motor was built to run exclusively on e85 with its much higher octane (hello high compression days of the 60s!) you would not notice nearly that severe of a decrease in fuel mileage.
its just like running your car on propane. just about any internal combustion engine can run on just about any fuel within certain constraints. as long as the fuel can be atomized and the stoichiometry can be maintained you are good to go. hell, if you look at the industrial application portion of gms web site you will see good ol' sbcs set up to run on propane or unleaded from the factory. but i digress.
gms flex fuel vehicles 'sense octane' and adjust accordingly. now whether this is done with an 'octane sensor' or just by paying very close attention to the o2 sensor i do not know.
however for those that are interested, you might ask HP Tuners if they have played with the octane sensing/adjustments on the flex fuel vehicles yet. if they have then with some work the 'tuning' will be done for you. dump in cheap gas for around town (just keep your foot out of it to help avoid detonation) run the fuel almost out of your car on the way to the track and stop at the e85 station on the way. By the time you get there your ECM has already changed your spark and fuel curves for you!
hooray electronics!
__________________
We want to gain knowledge from here, not spam. You don't need to withhold info from us to gain business, in fact you may do just the opposite as people will be less inclined to come by for your selfishness. There are so many more people on these boards that would rather take their cars to shops to get work done rather than do it themselves so the business is there and you do not have missed opportunity from unveiling the big E85 secrets. Just my $0.02.
