Corn Powered Corvettes!!!
Old Nov 4, 2006 | 06:37 AM
  #61
LS2Camaro's Avatar
"Subscribing"
Old Nov 4, 2006 | 09:29 PM
  #62
Ellwood's Avatar
I'm looking to run my other car ('75 Saab 99ems w/16v, big turbo, etc) on ethanol and I've dug up some interesting info. Here's what I've found out so far:
1. Ethanol is more corrosive that gasoline, especially with rubber and aluminum, think about all the O-rings, seals, fuel lines, injectors, etc that might need to be changed. Cars in recent years are much more tolerant of higher percentages and I beleive they are required to operate without issues on E10 maybe E20. (emissions rule, ethanol replacing MTBE for O2 content of the fuel) I've read many reports from folks running up to E100(pure ethanol) without problems. But I've never tried it my self. On the Saab I'm replacing EVERYTHING, from custom fuel cell to injectors. It's 30yrs old and was not designed for 300+ hp.
2. Ethanol has less 'energy' than gasoline. So you'll need more of it to to make the same power. The +30% number is correct, mathetically. BUT, it has a higher 'octane' rating so it compliments changes to build hp (upping compression, boost) nicely.
3. Ethanol is electrically conductive. I read an article describing the correct way to ground your fuel tank, pump, etc. I wasn't sure if the problem was electrical ground or sparks, but sparks flying in a fuel tank is bad for any fuel, eh?
4. Here's the part that really interests me: FlexFuel sensing. Considering point #2, I need to tune for a different AFR, #3 the fuel can conduct electricity; enter the FlexFuel sensor. By measuring current, resistance, or something (I'm not to good with electricity) the sensor reads how much ethanol is in the mixture. Look into MegaSquirt DIY http://www.msefi.com/) fuel injection systems (that's what's going on the Saab) There are several several post talking about ethanol. The sensor I'm planning to use comes from a GM truck, and hpTuners has support or at least, tables for flex fuel vehicles.
Now, how does the tuning work? Haven't figured out the details yet, but it was explained to me like this: The engine has base settings and correction factors for different inputs like temp, pressure, O2 sensors, etc. So baseline x correction for temps x O2 sensor corrections x Fuel composition...
Old Nov 4, 2006 | 11:14 PM
  #63
BLWN1's Avatar
[QUOTE=newby]. i thought it was cool that e100 is floating around out there somewhere. i dont have a station here yet that even has e85 so i haven't given it too much thought.QUOTE]
Yeah here in Ky, around NC and TN, we have had 100 for years.... and been in cars for years... its actually how nascar was started I think....
Old Nov 5, 2006 | 12:17 AM
  #64
Runn's Avatar
https://ls1tech.com/forums/fueling-injection/602091-how-run-your-ls1-e85.html
Old Nov 5, 2006 | 11:19 PM
  #65
Ellwood's Avatar
That's great stuff! One question: So you run only on E85?
Old Nov 6, 2006 | 09:09 AM
  #66
Runn's Avatar
Yes... i see no idea with changing back to gas when E85 is a better fuel.
Old Nov 6, 2006 | 11:05 PM
  #67
Ellwood's Avatar
Only thing I'd be worried about is what to do if there's no E85 available and last I checked there was only one station in the state of Florida that sells it. It's going to be a couple of yrs 'til it's as available as gasoline. I really like the 'FlexFuel' idea...
maybe I should get started building that still...
Old Nov 7, 2006 | 07:44 AM
  #68
Runn's Avatar
OK, Then you have to buy the flexifuelsensor that the Tahoe uses and update you PCM.
Old Dec 6, 2006 | 02:51 PM
  #69
Pecos Pete's Avatar
Maybe I can help. I have been playing with this myself. Since much of this is not legal for an on-road vehicle, and have some first hand "opinions" to offer. This is likely why their has not been a detailed tech build-up in any major magazine yet.
I believe to get the most out of an E85 fueled only (not flex fuel) LSx motor, one must increase the cylinder pressure so as to utilize more of the power out of the fuel. This can be done by either 1) increasing the mechanical compression ratio in the motor, or by 2) switching to a cam shaft with a wider lobe separation (113* - 114*) and longer duration similar to a camshaft utilized for a supercharger or nitrous application, or ideally both 1) and 2). A 12.5:1 to 14:1 mechanical compression using a supercharger cam profile would be a good combination.
The octane rating of E85 is 105 (RON), and it burns cooler than gasoline. This combination of high octane and low temperature provide high performance vehicles with suprisingly good fuel efficiency. A gallon of E85 has an energy content of about 80,000 BTU, compared to gasoline’s 124,800 BTU, so in identical motors, about 1.56 gallons of E85 will take you as far as 1 gallon of gasoline. It's the higher octane of E85 and the cooler burning allows a much higher compression ratio, which translates into higher thermodynamic efficiency. You have to squeeze it to get the all the benifits.
The motor will need larger injectors to deliver the ~30% more fuel per injector pulse too. Because of this, an E85 only motor will benefit from a larger intake runner volume, both in the intake manifold and in the head. Heads with 215 - 225cc intake volume are prefered over the stock 200 cc or the typical 205cc "Hi performance head for stock bore" recommendations the magasines usually show. The reason for this is the additional fuel being delivered to the motor will displace air in the intake runner, so the motor will benefit from larger runner volume here. The motor will benefit from a larger intake valve to allow the larger volume to pass; 2.02" ~ 2.08" ~ or even 2.18" valves are better. The customary ratio of intake to exhaust valve size for a given gasoline engine is different for an alcohol motor. In simple terms, the alcohol burns cooler as it passes through the motor so you don't need as much surface area on the exhaust valve perimeter touching the head for valve cooling, and the higher cylinder pressure helps move the exhaust gasses out of the cylinder allowing for the use of a smaller exhaust valve; 1.55". Use the smallest exhaust valve diameter and the largest available intake valve diameter. The use of the smaller exhaust valve will give you extra "real estate" to allow for the oversized intake valve. Forget the sodium filled valves, you won't need them due to the cooler motor operation w/alcohol. Use the F.A.S.T. LSx intake manifold for it's larger runner volume.
This article has parts and technical information that is relevant.
http://www.chevyhiperformance.com/te...system_review/
Using the above information, a basically stock LS1 short block, heads with a larger intake runner and a smaller combustion chamber, larger intake runner manifold, supercharger camshaft, and long tube headers, one could conceivably build a 5.7 LS1 motor that will rear wheel dyno well over 500 HP and 500 ft/lbs, without nitrous bottles to fill, and without going over 6000 rpms to do it, get ~25 mpg's on the freeway, your under hood temperatures will be noticeably cooler, everything internal to your engine, fuel delivery system, and exhaust will run much cleaner.
I am in Minnesota. I have over 100, E85 stations within 100 miles of me. Their are several versions of motors like this running around my neighborhood.
EDIT: in 2006 E85 has been ranging between $1.55 and $1.75/gal in MN.
http://www.tpis.com/
http://www.rune85.com/cornvette
http://www.dynotuneusa.com/
http://www.johnhaleymotorsports.com/
KEY WORDS - E85 Ethanol E85 LS1 E85 LSx E85 cylinder pressure
Old Dec 6, 2006 | 02:53 PM
  #70
Runn's Avatar
Nice info.
Old Dec 7, 2006 | 12:41 AM
  #71
LS2Camaro's Avatar
First off Very nice write up. This is excellent information. You are very lucky to have pumps where you are at, currently there isnt any pumps that I know of in Phoenix where my home is, but hopefully by the time I get home there will be some. Anyway I do have a question. Basically when going Forced Induction you need to lower the compression to about 8.5 CR because of the low octane rating of 93 or worse pump gas which the more boost you use the more easily the mixture can pre-ignite (which causes knock). So what Compression would you then want to change to if using strictly E85 (105 Octane). Lets say the internals are up to is, (Forged). Would it be okay to go say 10.1 CR and run the same boost (15 to 20psi)? Im just trying to figure out the ball park numbers.
Old Dec 7, 2006 | 07:17 AM
  #72
Pecos Pete's Avatar
Default I have no first hand experience, but...
http://autospeed.drive.com.au/cms/A_2776/article.html
http://72.14.203.104/search?q=cache:...s&ct=clnk&cd=1
This 383 LS1 is running a whipple with 10.5:1 static compression on 98 octane (RON) gasoline and using a secondary and separate water/methanol injection system to control knock.
I would guess if a similar motor were to use E85 105 (RON) octane ethanol as the motor fuel, the secondary and separate water/methanol injection system would no longer be necessary.
5 locations in AZ. 3 are in Tucson -
http://www.e85refueling.com/location...ad371e37b3da88
Check here for locataions in other areas -
http://www.e85fuel.com/need_e85.php
Old Dec 21, 2006 | 06:22 PM
  #73
DogNutz's Avatar
Very nice write up and thank you. I am in the process of building a 408 and plan on running strictly E-85 since station here in Missouri are also very plentiful. What compression ratio could I run? I was thinking 13:1, could I go higher even? I sure wouldnt mind running as high as possible. I have a Iron block and will be using 317 casting aluminum heads that will be ported and polished with 2.08 intake with 1.60 exhaust and I was thinking of going with a cam in the range of 248/254, .615"/.620" on a 112-113 and running a nitrous shot as well. Thoughts? Suggestions?
Old Dec 21, 2006 | 06:36 PM
  #74
383ss's Avatar
i think you could get away with around 13.5-14:1, but I am also looking for the same answer. also what DCR you can run.
Old Dec 21, 2006 | 09:29 PM
  #75
black_z's Avatar
I know it is an apples to oranges comparison, but my buddies all motor (B18) honda has a SCR of 13.9:1 and it runs great on E85.
Old Dec 21, 2006 | 09:41 PM
  #76
camaro98z28's Avatar
We don't have E85 stations here in AZ as far as I know. Lucky Bastards.
Old Dec 21, 2006 | 11:04 PM
  #77
'Trust''s Avatar
Speaking of CR's, what would the affects be power wise after switching to E85 on say a stock 10.1:1 LS1 with the proper tuning? Loss, gain, neither? Obviously you can only go so far with gasket thickness to bump compression, and even that is too much for the regular Joe that wants to run E85. Basically I guess I'd like to know if you can make at least the same power with the same CR moving from conventional gasoline to E85 with only minor modifications (tuning, and possibly injectors [I may have missed it, but do those need to be changed?])?
Old Dec 22, 2006 | 12:44 AM
  #78
rubbersidedown's Avatar
We've had 14:1 w/ nitrous- it works well. (9.86 @ ?134?- don't recall for sure- If I remember right he did 635 HP and 700 tq to the tire, I can look again in the morning) 355 cu in w/ 250 shot in a '81 malibu. We've had multiple LS1s with spray in the 12:1 range, and I have been on the engine dyno w/ a 38ish LS1 13:1. I won't get into tuning specifics but we've been there, done that for all of last summer. It works great for forced induction, too. I can post up more info in the morning. Stew on these for a while.
www.runE85.com/cornvette (corn powered C5s)
internal engine pics of a 427 on corn this summer and also a 5.7l on corn for 110k miles (for those worried about other problems)
http://www.rune85.com/internal%20engine.htm
Old Dec 22, 2006 | 07:14 AM
  #79
No Juice's Avatar
check out the numbers in my sig on E85. I'd say they are better than the average bolt on LS1. You should gain some on a stock LS1, I certainly did.
Old Dec 22, 2006 | 08:59 AM
  #80
Runn's Avatar
Got to love that corn fuel
