New Trick Flow Dyno Numbers
Changes are ported the FAST 90, Harland Sharp rockers, Meziere EWP, 236/238 .601/.608 113+3
472rwhp/418rwtq (493rwhp/437rwtq uncorrected)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I am very happy with the gains for essentially porting a fast and an EWP, there is definately more to be had. At this point though, I need to get the car track ready. I think changes I make cam wise from this point on are going to be for driveability and track times. I think the cam you spec'd out for me will be the biggest power wise I got, but would break the stock rear in a week. Trending Topics
Brian, For what reason are full roller rockers needed? Nice numbers BTW.
The way you achieve this type of geometry is by standing the rocker up, or raising it up and then pulling it away from the valve to get it closer to center. The problem with this type of geometry with stock LS1 rockers is they tend to sweep all the way out to the tip end of the rocker and then damage to the valve stem tip can occur. This type of damage is even occurring with 15 degree heads with stock rockers as you have seen other posts on this problem. There are many variables that factor into whether or not someone will have a problem, and any 15 degree head with bronze guides is going to suffer accelerated guide wear with stock rockers also.
Thanks Brian for the explanation.
Great information and it also confirms what I found setting up my Darts last winter. I couldn't get a very good pattern from stock rockers and went to the Crane 1.7 rollers, this was after a week or two playing with them on the bench and checking the wipe pattern. Got a much better and narrower pattern with the Crane rollers, but as stated above it sweeps from the inside to the outside with peak lift on the outside of the wipe pattern.
