ALL New PRC Stage 2.5 5.3L Head Results!!!!
#81
Originally Posted by NHRAFORMULA00
Holy **** is what i said after 2 nice and easy shake down runs.Then i clicked off a 10.79,10.76 then last one was a 10.75.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#84
After read this thread I'm going crazy, I can't wait to put this set up on my car, my install date is 30 may and dyno tuning on or around the 2 June. The TSP guys are a class act shop that takes the time to help you out and answer all your questions. I can't say enough about them. Thank-you TSP and my numbers to follow!!!!!!!
Below is the build list!!!!
- Precision Race Components Stage 2.5 5.3L Heads Fully CNC Ported & Assembled With Stainless Steel 2.04" Intake Valves, 1.575" Exhaust Valves, & PRC Dual Valve Spring Kit with Titanium Retainers
- Texas Speed Torquer v.2 Camshaft the Texas Speed Torquer 2 232/234 .595/.598, 114.
-Texas Speed & Performance Chromemoly Pushrods
-TSP Ported LS6 Oil Pump
- Roll master Single-Roller Non-Adjustable Timing Set
- GM Replacement Lifters, LS7 style lifter
- FAST 90MM intake
- FAST 90mm Throttle body.
- Injectors SVO 30lbs.
- Basic Heads & Camshaft Bolt & Gasket Kit
- LS1 Powerbond underdrive pulley V8 with belts and bolt
Oh, I almost forgot, Yank 3600SS stall converter and a 2400 Tran cooler also.
- FAST 90MM intake
#86
update the car got weighed and raceweight is 3275 with driver so car is 3275-195 = 3080...lighter than we thought...wish my car was that light with a cage and 12 bolt...
