cam retarding Need new tune?
has a comp 240/248 609/615 112+4 cam. it was tuned with this cam installed dot to dot. at the dyno the car flatlined at 5300 and carried it to 6300 before droping like bricks. I wanted it to spin much higher so I retarded my cam 6 degrees. basically -2 degrees since it has 4 degrees ground in. this brought my dcr from 9.37- 8.77. static is 11.5. Pump gas motor. anyhow I knew it was going to lose bottom end but it doesnt seem like its picked up any top end. Is this a result of the tune or the cam not working well up top? Just dont want to spend all the cash to get back on the dyno if there is a problem.
TIA
Mike
TIA
Mike
car thumps alot more crisper and revs a ton cleaner. just pulling just like it did before up top.
