H/C setup for 450RWHP N/A
Old Nov 30, 2006 | 08:39 PM
NYRDRMSS's Avatar
Default H/C setup for 450RWHP N/A
What H/C setup on a full bolt on 346 will consistently produce 450 RWHP N/A?
I have been leaning toward TSP 233/239 with a Patriot Stage II setup but now I am thinking there may be a better setup. Maybe something that works well with spray also? Thanks for any info.
Old Dec 1, 2006 | 09:27 AM
Nasty Hawk's Avatar
I know my buddy pete (sprydncamd) is laying down about 450 rwhp all day
F-13 cam
Dart 205 heads
Harris speed tune.
Good Luck
Old Dec 1, 2006 | 11:30 AM
Sigforty's Avatar
Try this in the internal engine section. I know some bolt ons a f14 cam and dart 205s did it for me.
Old Dec 1, 2006 | 11:37 AM
pushinfreight's Avatar
It can be done. Mine does it. I have ported and milled ls1 heads with 11.7:1 comp 236/230 cam, longtubes and it puts down 450 rw on tr6 plugs all day long with pump gas.
Old Dec 1, 2006 | 02:28 PM
TRMIN8R's Avatar
Mine did 490. TSP MS3, TSP 200cc Terminator Heads, FAST 90/NW90 and full bolt ons. It did 491/427 and that's on a nitrous tune, prolly could have gotten a bit more with a little more timing and a little less fuel.
Old Dec 1, 2006 | 03:03 PM
98SS2836's Avatar
See sig
Old Dec 1, 2006 | 08:56 PM
SLowETz's Avatar
440/400 through a TH400, steel DS, 12 bolt, 4.56 and 28" slicks with a set of 3 year old TEA 5.3's and a little itty bitty F11 cam slapped together in the garage.
I'm guessing the motor combo through a lighter driveline(DS/10 bolt/3.42-3.73's) would be ~ 475 or so. Same combo went 460/424 through the M6. Made the number every time
Bigger eent always better. Do the obligatory bolt ons and MATCH the H/C and you'll get your number-
Old Dec 1, 2006 | 11:20 PM
allngn_c5's Avatar
Definately with 98ss2836 on this one. The g5x3 cam with AFR 205's plus boltons with proper tuning will yield 450+ rwhp all day long.
Old Dec 2, 2006 | 06:32 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Do you already have a 233/239? Checkout some results in this section from the Precision Race Components heads. I think you'll find the heads out power the competitions cylinder heads in almost every thread. Run a search for recent results & check out the PRC heads consitancy compared to some of the other cylinder heads....
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Dec 4, 2006 | 02:29 PM
Chris Gage's Avatar
The TSP boys can def. help you out, They have some pretty good combo's that have proven themselves on the dyno and track. Give them a call and let them kow what you want from your car as far as possible ET's, numbers, streetability, etc.
The only other heads I would put over the PRC's are the TEA ported TFS's... but you are talking big money when coming to the TFS heads.
Old Dec 4, 2006 | 06:27 PM
NYRDRMSS's Avatar
I have not bought any cam yet, I am looking to eventually spray the car so I
want a cam that works good with nitrous also, However I do like the sound of
the TSP 233/239 cam with True Duals does anyone have dyno numbers on this cam with a good set of heads???
Old Dec 4, 2006 | 06:42 PM
01sscam's Avatar
Man-Crush Warning
TSP MS4, PRC stage 2.5 heads, Fast 90/nw90, bolt ons, 485rwhp. i'll be picking up some more when we retune. Call TSP and they'll be able to get you set up i'm sure.
Old Dec 4, 2006 | 07:23 PM
Prophecy's Avatar
made 440rwhp/400rwtq with home ported LS6's and a 232/238 .605/.605 and bolt-ons Will make 450+rwhp once i put on a pulley and Electric waterpump....
Old Dec 5, 2006 | 06:27 PM
chris93266's Avatar
check my dyno thread...
233/239 & prc stage 1 ls6 cnc heads with competition valve job
442 sae through a stalled auto with tr6s on a conservative dynojet
Old Dec 5, 2006 | 07:04 PM
pdd's Avatar
pdd
im shootin for 450rwhp through 4.10's with my setup
Old Dec 5, 2006 | 08:46 PM
Good Doctor's Avatar
g5x3/112 and afr205s @ 59cc is a proven setup that does 450 every day of the week
Old Dec 6, 2006 | 07:58 AM
TVWilkes's Avatar
The PRC setup thru Texas Speed will give you the results your looking for.
Old Dec 6, 2006 | 08:38 AM
Patrick G's Avatar
LS1 Tech Administrator
With the right head chamber size (59 cc), tight quench (.040") and the proper intake (ported FAST 90), you can make over 450 rwhp even when running a small cam. My cam is a 223/227 LSK lobed cam (measured 224/228 actual). You'd be amazed how docile a 475 rwhp car can be when it's setup right. All these huge cams (MS3, MS4, T-Rex) are unnecessary to achieve 450 rwhp if you sweat the other details. All you need is a quality head...pick one (PRC, TEA, TFS, RHS, AFR, ETP, Patriot, LPE). They will all get you there as long as you follow the recipe (high dynamic compression, correct overlap, correct intake valve closing point, tight quench, unrestricted intake).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 6, 2006 | 03:35 PM
jmarsa's Avatar
I've been wanting to ask this for a while. For the same HP goal as the original poster. Is there a preference for either a smaller chamber like the 58cc Patrick refers to as opposed to a custom piston and a larger chamber like 67cc when both yield the same DCR/SCR?
--JMarsa
Old Dec 6, 2006 | 04:27 PM
Patrick G's Avatar
A small combustion chamber and a flat top piston will concentrate the burn to the center of the piston which does 2 things:
1. It allows the burn to happen faster because the flame front is shorter. This will allow you to make more power with less timing.
2. The side benefit is you can run more static and dynamic compression on the same octane.
Said another way: A 58cc chamber with a flat top piston may allow you to run 11.5:1 static compression and 8.5:1 dynamic compression on 91 octane, whereas a 68cc combustion chamber with a dome piston may only allow you to run a maximum of 11.0:1 SCR and 8.2:1 DCR safely on 91 octane. The extra compression will make more power on the same fuel.
__________________
