UNTUNED dyno of 408 in Hawaii
Old Dec 3, 2006 | 12:59 AM
1fastTransAm's Avatar
From: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
Default UNTUNED dyno of 408 in Hawaii
Click here to see Video
Any tunners HELP please..
Old Dec 3, 2006 | 01:31 AM
silverbeast's Avatar
Well for one your air fuel ratio is way off. You need to get it down to around 12 and a half to 13 from 4375 rpms all the way to red line. how much timing are you running?
Old Dec 3, 2006 | 01:32 AM
Im thinking you are running really lean. be careful you dont hurt your motor. im not a tuner but thats what it looks like to me. good luck and enjoy your car after you get it right.
Old Dec 3, 2006 | 03:16 PM
SIC LSX's Avatar
bump he needs help
Old Dec 3, 2006 | 03:27 PM
DONAIMIAN's Avatar
Time to order tuning software and a wideband. Id try not to drive the car if possible untill you get that taken care of.
Old Dec 3, 2006 | 03:33 PM
Houston999's Avatar
If i were you , the only time that i would drive it is to get it tuned
Old Dec 3, 2006 | 04:50 PM
bad95killer's Avatar
Indeed cause if ya keep running her like that ya gonna be sorry buddy so get her tune is your first periority .
Btw what is the CR buddy ?!
peace
Old Dec 3, 2006 | 05:04 PM
Magnet's Avatar
tune that biatch!!!
Old Dec 3, 2006 | 06:59 PM
MeentSS02's Avatar
Kleeborp the Moderator™
No WOT for you!
Seriously...lay off, or you are gonna have an expensive paper weight.
Old Dec 3, 2006 | 09:10 PM
MSGHUFF's Avatar
Damn you'de think the dyno operator would have let off when he saw it leaning out....
Old Dec 4, 2006 | 08:26 AM
Brian Tooley Racing's Avatar
You have 12.8:1 air fuel ratio at 4000 rpm and still only 350 lb ft of torque.....you have way more problems then tuning.
Old Dec 4, 2006 | 09:27 AM
dynocar's Avatar
Right on.
Old Dec 4, 2006 | 10:37 AM
DONAIMIAN's Avatar
With the graph being broken up like it is, do you think it could be a detonation problem?
Old Dec 4, 2006 | 10:54 AM
dynocar's Avatar
Up to 5750 it looks like a KR problem, at 5750 on up it looks like a combination of KR and detonation.
Old Dec 4, 2006 | 12:54 PM
SIC LSX's Avatar
Something must to be wrong! I did close to the same #'s with just a cam with same A/F But my injectors were at 109% But im around 405whp now with injectors,Tune,ported TB,ASP underdrive pulley.
Note this was on stock tune and b4 all my new mods above!
My car is a 99 too crapy heads
Old Dec 4, 2006 | 02:46 PM
Brain then what else do you think it could be asides from a tune problem? Cause I have no clue. I get a back fire from time to time at low RPMs It smells like its super rich but on the Graph it shows super lean. The only thing wrong I can figure out is a small exhaust leak off the Y-pipe. It burns gas like its rich a whopping 13.2MPG.
Its an FFHP 6.0 Stroker 408
PRC 6.0 stage 3 heads that where tounched up a tad by FFHP
TSP Gaint Cam 248/252 611/613 on a 113LSA
Hooker 1 7/8 longtube off road Y
SLP underdriven
its a SpeedDensity car
MTI clear lid
MSD 8.5 wires
NGK tr55 plugs
Now running Mobil 1 full syn
always 91 or better gas
stock rockers
42lucas injectors
Ractronix 255l system
6speed car
Oh the exact details for the motor I didnt get cause of what happend with FFHP I know it was built for spray. But anything else I am cluless I never got my blue sheets or anything
Need anything else?
THanx Chris
Old Dec 4, 2006 | 02:54 PM
SIC LSX's Avatar
well you can be rich at low RPM's and lean up top with a crapy tune!!!! Thats howm ine way b4 i got it touched up
Old Dec 4, 2006 | 02:59 PM
98Z28CobraKiller's Avatar
Restricted User
Looks like my dyno when my cam was out a tooth.
Old Dec 4, 2006 | 08:56 PM
BigBronco's Avatar
Glad I am not the only one who noticed it.
What cylinder heads and cam are in the motor?
Old Dec 4, 2006 | 08:57 PM
BigBronco's Avatar
wow, what do those heads flow... with that cam your power should still be up.
By Brett Foote | 2026-06-04 05:00:17
