Home ported 241 400+ rwtq on 3500rpm
Old 12-27-2006, 02:49 PM
speed_demon24's Avatar
Originally Posted by prostock_bigblock
the car owner is planning to squeeze out more power by adding more timing, maybe 31*, add a cutout, 32 injectors, 85 mass air and probably a match ported fast.
the car has alot left also in the tuning, the guy who tuned is a beginner and tuned it on open lope (WOT) .
You have a nice dive in power around 4K, you sure thats not knock retard?
Old 12-27-2006, 03:24 PM
prostock_bigblock's Avatar
no thats not knock. what ever that is ,its not knock for all i know.
Old 12-27-2006, 03:52 PM
Abdullah's Avatar
Heyy all this is one of my freinds car . Its a 98 camaro with the following mods:-
241 home ported heads with 2.02/1.6 valves.
228/232 112 lsa.
Asp UD.
ls6 intake and home ported Tb
ls6 clutch with aluminium flywheel
LTs with TDs to the all way back
stock 10:1 compression ratio.
stock injectors and they were maxing out.
unmilled heads.
stock mass air.
timing is at 26*.
here is the graph
prostock_bigblock, see my thread https://ls1tech.com/forums/showt...98&page=1&pp=10
can you e-mail me at kandery@yahoo.com the way on how did you port the 241 heads! thanks.
Old 12-27-2006, 06:04 PM
the link is not working, and ya i can e-mail u with the pics if u want to. I have done my 317 heads that r exactly the same work done on this 241 heads. However, I will pick up my heads tomorow from the flow bench to see the results.
mine with stock valves though.
Old 12-27-2006, 07:44 PM
wicked@boost's Avatar
I think this car has more to produce.
very nice numbers.
Congrats.
Old 12-27-2006, 08:06 PM
Originally Posted by BADFNZ
Maybe this setup is so good it defies the laws of physics.
I think its very achievable, no law of physics or any of that BS. The owner installed every part by him self, ported his heads and tuned it a beginner. Furthermore, the owner doesn't know english and never been in the states and never been to this forum or any other.
Old 12-27-2006, 09:05 PM
98camaroLS1M6's Avatar
very nice setup, must haul on the street!
Old 12-27-2006, 09:19 PM
Abdullah's Avatar
here is the link again :
https://ls1tech.com/forums/showthrea...8&page=1&pp=10
and here is my e-mail : kandery@yahoo.com
thanks.
Old 12-27-2006, 11:52 PM
BriancWS6's Avatar
this is one of the best tq qurves i have ever seen personally, is there anybody who r making similar numbers on a mild setup like that?
Here's my graph.
Stock LS6 intake, AFR205s, cam is a 228/230.
Old 12-28-2006, 01:58 AM
Originally Posted by BriancWS6
Here's my graph.
nice, what cam is that?
Old 12-28-2006, 02:10 AM
bad95killer's Avatar
It's right under the graph buddy ya must had a tough day .
peace
Old 12-28-2006, 02:17 PM
  #32
I should asked what brand cam is this 228/230.
Old 12-28-2006, 02:20 PM
  #33
peace
even If I had a tough day I wont be blind .
Old 12-28-2006, 04:57 PM
  #34
BriancWS6's Avatar
It's a Comp XE-R grind, on a 114+1.
Old 12-28-2006, 05:12 PM
  #35
Justa Z's Avatar
Old 12-28-2006, 05:41 PM
  #36
02SOMWS6's Avatar
I put down 452rwhp and 408rwtq with a set of ported 241's and a smaller 224/228 581/588 cam . That was done with a 12 bolt that has 4.30 gears. anything closer to the stock gears would have put down better #'s.
Old 12-28-2006, 08:01 PM
  #37
actually our main emphasis was on low end torque and we're still talking stock compression.
i am not trying to knock you down your numbers are tough to beat. can you tell me the rest of your setup?? is that 10.6 pass n/a?
Old 12-28-2006, 08:46 PM
  #38
02SOMWS6's Avatar
The 10.6 pass was before my retune where I picked up 22rwhp and 34rwtq. That pass was on a 75 shot and the car went 11.2 NA before the retune. Hoping to go 10.9 NA and 9.9 with a bigger shot once my stand alone fuel system is hooked up.I couldn't spray more than a 75 shot before with out running my fuel system dry.
