dynoed my bone stock 99 Viper
No sadly their is no drag strip in Oahu hawaii since Mar 2006..
But my 99 model runs any were from 11.7-12.3 at 115.9-121 mph. Depending on track conditions and who's driving...
The slowest magazine review I have personally seen is 12.3 at 115.9
http://www.edmunds.com/insideline/do...97/pageId=3352
The fastest review i have seen is 11.7 at
http://findarticles.com/p/articles/m...05/ai_n9239712
You can look at the above list and see that their are many people running low 12's and high 11's bone stock in Gen2's just like mine..
one of the biggest misconceptions in that people think the newer SRT10's are that started in 2003 are faster than a 99 like mine..
On the dyno mine can put down a max of 420 rwhp stock while the SRT 10 can put down a max of 450 rwhp stock..
So across the board they have 30 more rwhp on average..
So they should be a little quicker right?????
well they would if they didnt have 19 inch tires..
The gen 2's like mine have eighter 17 or 18 inch tires depending on the year..
When you already have crappy 3.07 gears. Making the 2003 SRT10's have 1 inch taller tires defiently didnt help with performance..
Then gen 2's like mine have pilot tires wich are actually pretty grippy. The SRT10's on the other hand have run flat tires wich suck at the drag strip...
The record for a gen 2 viper 100% bone stock is 11.6. The SRT 10 viper has yet to beat that record..
So it's kinda funny sometimes when i tell people that my viper can do high 11's bone stock at 120 mph..
they find it so hard to beleave because thats what the 2003-2006 NEWER 510 HP vipers can do and think mine will only do 12.4 at 115 mph.
But look at that list above..30 rwhp obviously got off sided by the 1 inch taller tires and run flat tires..
because their is hardly any differance between a 1996-2002 Gen 2 Viper and 2003-2006 gen 3 viper as far as 1/4 mile is concerned other than the way they look.
Nice numbers man ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
My buddy's 98 Viper GTS with Venom 600 Engine Upgrade puts down 529rwhp/547rwtq SAE three months ago 90+F & 80+ humidity
![](http://img.photobucket.com/albums/v229/Bad95killer/DamnViper.jpg)
I'll try to scan the graph to post it over here though .
peace
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
peace
Originally Posted by 5_02ls1
the vette and the f use the same cam.98000=o.498
00up=0.465.the early 385hp (zo6)had the0.525 cam .the hp is 350ish on all ls1 cars.gm rates the vette higher to sell th overpriced thing.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by FU_I_AM_UltraZ
yes, the early 385hp z06 had the .525 lift, when they switched to the .551 lift it went up 20 hp. so the LS6 heads add 35hp to the LS1. so, 350hp + 20hp(cam) and heads(35) = 405hp. the vettes always have had upgrades over the f-cars. LT1..they had better heads. LS1 they have better cam. LS6 intake is only rated at 325 over the previous 320 hp b/c of the .500 lift on the cam. if you broke down all the parts like i just did for the LS6, the number add up and match perfectly. a GM heavy duty tech showed my that when i worked at a chevy dealership and asked him to install a cam and which one would be the best daily driving cam from the GM performance selection.
a 305 hp car will not put down 300+hp at the wheels
#32
yeah the zo6 had a cam ,better heads all 01-02 cars had ls6 intake.do a part# search at your local dealer on a 98 vette cam then a 98 fbody ill promise you the #s will match.all ls1s have the same hp.a 305 hp car will not put down 300+hp at the wheels.use the SEARCH button before tryin to look smart the next time
#33
good luck on 600 rwhp. I think it was svs that just made 650wrhp on an all motor setup. I set of those stryker heads should work pretty good, although they'll set you back a few. 600 should be doable with a decent H/C package and all the supporting mods (T&D, a good set of headers, smooth tubes etc.) Who's going to tune the car if I might ask? The svs car was fast as **** or so it seemed. altough the car acted a little wierd when racing, if I had to bet, my guess is that they were spraying a 150 shot on it too.
#34
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#35
Bakc on topic:
I cant wait to see what the 08 vipers lay down since theyre upping the displacement to 8.4L w/600hp. Also with a lot more color choices. Should be a sick car.
#36
Originally Posted by Red99TA
Looks like it's time for you to use the search button
As mentioned there are plenty of stock f-bods putting down 300+ at the wheels. GM underrated the HP of our cars a LOT. I used to have a '98 "305 HP" trans am that dynoed 311 RWHP with only an aftermarket catback exhaust.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#37
Originally Posted by DONAIMIAN
Bakc on topic:
#38
#39
You sure about that. Its plenty of stock cars that put down that or a little better off the showroom floor.
#40
Originally Posted by speed_demon24
It looks like thats exactly what hes trying to say, they put down 300+rwhp because they have more than 305hp. ![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
