VIDEO at Idle plus streetability and WOT with my 511rwhp / FTI
Old 11-12-2013, 09:30 AM
  #181
miami993c297's Avatar
Originally Posted by dr_whigham
Maybe it's bc I'm on an iPhone... I can't play the PhotoBucket videos. At all
The links in the first post are still active...
Anyway find below 3 fresh links from the original videos:
01-27-07 IDLE Inside & Out
01-27-07 Cruise around West Palm
01-27-07 WOT 185 MPH
Power curve
Christian
Old 11-12-2013, 11:39 AM
  #182
Super Hulk Smash
JakeFusion's Avatar
Thinking this cam for your Vette?
Old 11-12-2013, 12:04 PM
  #183
The Scammer Hammer
dr_whigham's Avatar
Thinking of flat out using Christians BUILD as a blueprint, lol.
Old 11-12-2013, 01:54 PM
  #184
The Scammer Hammer
dr_whigham's Avatar
Christian, thanks for reporting the videos. I'm pretty sure it's just my iPhone issue.
Correct me if I'm wrong, but these #'s were made through the stock Titanium catback?
Old 11-12-2013, 02:27 PM
  #185
LGM 1 3/4 Long Tubes, High Flow cats, OEM Untouched Titanium Catback...
Do not forget, this engine entire recipe is from Ed Curtis!!!
Christian
Old 11-12-2013, 04:03 PM
  #186
Super Hulk Smash
JakeFusion's Avatar
See, Dave. You don't need to ditch the Corsas... But I would and find something with some *****.
Old 11-12-2013, 09:33 PM
  #187
The Scammer Hammer
dr_whigham's Avatar
I'm thinking they'll wake up A LOT when I ditch the FOUR cats!!
Old 12-03-2013, 06:05 PM
  #188
cguth's Avatar
I am going to do the same. Totally awesome that all the specs and all needed parts are in this thread. No secrets and no smoke. Very informational thread.
Old 12-03-2013, 07:41 PM
  #189
The Scammer Hammer
dr_whigham's Avatar
Just don't forget where all those parts, specs and thought came from...
Old 12-03-2013, 08:38 PM
  #190
I have to admit I throw at this engine anything I could, high speed rush way above any reasonable reality in ant condition, very high speed, upshifting any gear at 7500rpm / 7300 rpm, never thinking about saving any part of this engine...and this engine never failed nor disappoint me.
If I had to build again a Gen III LS stock cubes...I will ask Ed Curtis to duplicate an updated version of this baby, period.
Christian
Old 12-04-2013, 08:52 AM
  #191
I am going to update this thread with fresh links to the pictures of all the parts coming from Ed Curtis as I saw broken links within the middle...
Christian
Old 12-04-2013, 09:26 AM
  #192
The ETP milled to 60 cc :
The ETP 215 intake side :
The ETP 215 exhaust side :
The ETP prepared with the upgraded FTI PS4 Valve Springs :
The SCR is around 11.45 acording to the calculation of Ed Curtis.
And with this camshaft:
The Cometic Head Gaskets :
Morel Billet Hydraulic Lifters:
The Adjustable timing chain:
The Three Piece Pro-Series Heavy Wall 8.100 Push Rods:
The Chevy LS6 OEM ROCKERS Trunion Upgrade:
The Melling high volume low pressure oil pump:
ASP Underdrive Pulley:
The Injectors and Data test sheet:
The Engraved injectors numbered by flow versus cylinder:
The FAST 90 Ported and IAT Sensor relocated:
The 90mm Ported TB:
The Intake filter and Carbon Fiber Powerduct without MAF:
The deleted PCV valve systems with Vented Catch-can in the car:
Christian
Old 12-04-2013, 03:40 PM
  #193
Rise of the Phoenix's Avatar
Never gets old looking at this Thread.
Old 12-05-2013, 12:33 PM
  #194
And I cannot forget the very So Famous Original StreetSweeper by Ed Curtis with the Original Comp-Cam card (maybe not completely...):
From what the rumor says, multiple time copied...but never ever really.
Christian
Old 12-08-2013, 09:22 PM
  #195
The Scammer Hammer
dr_whigham's Avatar
Originally Posted by miami993c297
And I cannot forget the very So Famous Original StreetSweeper by Ed Curtis with the Original Comp-Cam card (maybe not completely...): From what the rumor says, multiple time copied...but never ever really. Christian
Indeed. Proprietary lobes have their place...
Old 04-29-2014, 01:09 PM
  #196
And still today this set-up is intriguing members...
I received a PM with some pertinent questions about the ETP Cylinder Heads and the StreetSweeper camshaft from Ed Curtis...
The specs are in the link below:
http://www.flowtechinduction.com/fti...eper-camshaft/
Christian
Old 04-30-2014, 08:21 PM
  #197
studderin's Avatar
haha I figure something was up, got some questions too about this hidden gem.
https://ls1tech.com/forums/parts-cla...m-package.html
Looks like this is whats its about. this setup is listed FS right now.
streetsweeper cam, ET heads and setup spec form ED. Somone was rocking the setup in there GTO
mustang dyno STOCK shortblock
503whp 450 wtq
Old 07-08-2014, 11:07 PM
  #198
lxcoupe's Avatar
503whp 450 wtq
I purchased Anthony's heads, been slowly and carefully accumulating parts to do the install on my Z06.
Anthony used stock GM MLS gaskets, as well as LS7 lifters, and spec'ed the Manton pushrods for those two items. Obviously I will check pushrod length once the heads are bolted down, but I plan to use LS7 lifters for this build. Anyone see an issue with that? Anyone replace LS7's with Morels, and use the same pushrod length?
Old 07-09-2014, 06:33 AM
  #199
The Scammer Hammer
dr_whigham's Avatar
Originally Posted by lxcoupe
I purchased Anthony's heads, been slowly and carefully accumulating parts to do the install on my Z06. Anthony used stock GM MLS gaskets, as well as LS7 lifters, and spec'ed the Manton pushrods for those two items. Obviously I will check pushrod length once the heads are bolted down, but I plan to use LS7 lifters for this build. Anyone see an issue with that? Anyone replace LS7's with Morels, and use the same pushrod length?
You don't need them. Time to throw in the towel and just sell it all to me...
Old 07-12-2014, 09:27 AM
  #200
Do not compromise...Morel lifter is the way to go.
Christian
Quick Reply: VIDEO at Idle plus streetability and WOT with my 511rwhp / FTI
