Estimate RWHP?
then go get it tuned and dyno'ed
i'd say maybe 340 - 350
That chip wont work unless you have a flux capacitor.
That chip if it does anything at all, wont help you, let the PCM control the spark timing, dont fool the PCM, it relys on accurate sensors, if you put crap in you get crap out. Same as a MAF translator fools the PCM too.
I would prefer to tune myself, you are the only person who is willing to get great results, many other tuners (not saying all) do it for money. You will give it the attention required, asmittedly there is a learning curve. The two main ones to choose form are HP Tuners and EFI Live.
The clutch wont give you any power increase. But the other parts with a tune I'd say about 25 to 50rwhp extra. Depends how far out your current tune is. Also if you are getting into tuning look into getting a WB sensor and guage, then you can tune for WOT.
get it dyno tuned!!! it's worth it. prgramer w/o dyno tuning the car will probably give you only 345rwhp if your lucky. you should be above 350rwhp. my numbers in my sig. are 2 years old. untune and burned out plugs i made 335ish rwhp, dyno tuned, 351rwhp and plus the SLP under-drive pulley 353 and 370 rwtq.
point blank, get it dyno tuned. worth it.
, so....330 at the wheels.
