98 A4 tr224 some bolt ons
Old Mar 17, 2007 | 02:49 PM
Bader-X's Avatar
Default 98 A4 tr224 some bolt ons
1998 A4 Z28 :
bought the car almost a month ago and heres what it have:
129700 miles
LT,ORY,LS6 intake,Lid,slp CAI,ls6 oil pump (don`t know ported or not only from tr as he said)
new MSD wires
new fuel pump and filter
new AC Delco spark plugs
new AC Delco Air Filter
and the owner said it had a tr224 three months ago with comp 918 springs installed, the cam card said 224 224 56x 56x 114.5 lsa
a muffler or catback is out of the question (tickets and an inspection to make sure you removed it here!) I actually removed the flowmaster and put a stock muffler.
any way it dynoed this in third gear (don`t know locked or not) on a dynojet :
STD: 329.67 hp 325.12 tq
SAE: 321.24 hp 316.80 tq
thought I`ll do 34x hp and 35x tq at least SAE....
(is this sh*t cammed?)
I see people with bolt ons on the board with the numbers I hoped for with a cam!
the idle is good many people didn`t know it`s cammed (although it rarely dip down and die in traffic at stops mostly I think with the a/c on but it did it without)
it idles hot at 800-900 sometimes 1100 rpm.
don`t think it`s tuned because the O2 and egr codes are still not removed and in N the rev limiter is around 6k rpm plus it has a speed limit at 160 mph ... but the thing is that the a/f ratio is pretty good as you`ll see from the dynosheet (13.2 going down to 12.8 from what I can see)
but my speedo is off arond 12-14 mph reading more than actual (maybe the aftermarket 17 rims that the owner put) or the whining 3.2x rear that I don`t know the original an upgrade from a 2.7x.
it drives like a stock car (good I didn`t spend the money on that cam ) but there is a trans problem when at full throttle it hits the rev limiter a few times before going to 3rd but at normal driving no problem .....and from a 26-30 driving the full throttle it`ll take some time to shift back to 1st (more than normal) ... a trans shop said there`s no trans codes and mostly it`s a bad converter.
don`t know how to post the pic directly I might learn and try but maybe someone will do it
(what do you think I should remove from the thread I wrote too much I think it`s kinda boring and not necessary)
Attached Thumbnails 98 A4 tr224 some bolt ons-clip_image001.jpg   98 A4 tr224 some bolt ons-clip_image002.jpg
Old Mar 17, 2007 | 04:22 PM
jetlag's Avatar
Hmmm..that does seem pretty low...my car dynoed that much with just Longtubes/lid/tune.
Old Mar 17, 2007 | 04:30 PM
Grimes's Avatar
Well, he doesn't know if the converter was locked or not. That would make a big difference.
Old Mar 17, 2007 | 04:44 PM
mpe488's Avatar
Take it to the track and find out what it runs. After that horsepower doesn't matter. I only dynoed 271 with an open cut-out otherwise stock. I was pretty bummed, but I trapped 103 which isn't great for a 3.23 car, but not as bad as my rwhp would have me guess.
Old Mar 18, 2007 | 03:46 PM
Bader-X's Avatar
dyno sheets attached.
mpe288 no track here yet had an 1/8 mile track and was closed .... long story but never ran there in any car.
Old Mar 18, 2007 | 03:54 PM
'Trust''s Avatar
That is low really no matter how you slice it. Are you on the stock transmission? It appears to be tuned (by your AF and that you're idling 800ish in an A4). I had the same issue on my old 98' motor. It had about 130k on it, longtubes, TR224, and a lid. Unlocked it did almost the same numbers unlocked on the stock tranny, locked it did 342/348. My cam was a 224/224 .563/.563 112 LSA (you said yours was a 114.5, they didn't make a 114.5 [a 114 yes], so it may be a custom grind). Now with the same cam, stage II 241's and a stalled A4 it does 400/380. The shop really thought that my old motor was just tired.
Old Mar 18, 2007 | 04:36 PM
Bader-X's Avatar
the cam card said 114.5 I think he ordered the 114 lsa and this is what the card said (I think it`s usual)..... and yes it`s the stock tranny.
why did he (if he did) tune it without removing the egr, rear O2 codes and didn`t rais the rev limiter and increase the shift point (with the shift stiffness if desired)? that`s just stupid if he did.
then the numbers are normal if it`s almost the same as yours when cammed only unlocked.
Old Mar 19, 2007 | 12:12 AM
5_02ls1's Avatar
sounds like the gear has been changed the tires wont make a 17mph difference.find a used handheld to recalibrate the shifts.
Old Mar 19, 2007 | 12:14 AM
'Trust''s Avatar
May have been a mail order tune and forgot to specify, rev limter, well that cam doesn't make much more power up high so it wouldn't help too much, shift points, no need if the limiter hasn't been changed and tranny untouched.
