First run on the dyno and It sucks
Old Apr 22, 2007 | 11:53 PM
killerinparadise's Avatar
Default First run on the dyno and It sucks
Need some serious tuning any ideas why I am running so lean?? Car has 62k on it and to my knowledge there has been no previous tuning, my current mods are in the sig, I think my O2's may have been bad at the time so replaced them but I still don't feel any significant change, what else should I look into? we only ran it once on the dyno and I don't want to drive it around till I get this fixed, should I get a dyno tune or is there any better way to look into this, If anyone around the Buffalo, MN area has a wideband I could use to see if the 02's helped I would greatly appreciate it. FYI that's 17+:1 A/F ratio
I thought I read somewhere that at WOT it is the MAF that controls fuel should I look into this?
Old Apr 23, 2007 | 09:56 AM
DANOZ28's Avatar
sorry i'm probably zero help but cant u have doug rippie adjust A/F ratio? if thats too expensive maybe mail order tune to get close however my mail order tune got me to 13.8 :1 still to lean. tpis, hi tech will all be expensive but do you want it done right? good luck
Old Apr 23, 2007 | 10:29 AM
LostCauseZ06's Avatar
clogged catalytic converters???? thatd be my bet.... there is no way in hell your car is running that lean... it would have been popping/detonating to high hell on the dyno....
Old Apr 23, 2007 | 10:52 AM
WS6FirebirdTA00's Avatar
MAF sensor, check for codes. I have seen them do this before, yet not throw codes also.
Old Apr 23, 2007 | 02:21 PM
I thought so too it barely moved his sensor from the highest it can read, I've bought some new plugs incase I f'd the ones in there right now from running so lean, I'm going to pull the plugs, do some compression tests look for any leaks in the exhaust, pull the cats see if there clogged, clean the MAF and maybe run some fuel injector cleaner through it, hopefully I'll figure out whats the deal after all of that, if not it's off to the shop, anyone know how I can test the MAF without a tuning program?
Old Apr 23, 2007 | 06:01 PM
GreenBlood's Avatar
hope you get it straightened out so that you can enjoy all of the performance...
Old May 5, 2007 | 07:43 PM
ryanisfast's Avatar
Yeah, might be the catylitic converter. Happened to me once on an old car i had and made a huge difference. I just kept driving the sh** out of and it finally blew a bunch of honey comb lookin stuff out the tailpipe. Then I had my power back and a little more top end power from the loss of it. Although...I did notice that when my catalytic converter clogged a had a lot more low end torque, but after 2500rpm, it would barely climb the rpms.
Old May 5, 2007 | 11:35 PM
massls1guy's Avatar
Have you changed your fuel filter? That's where I would start. And then check the fuel pressure.
Old May 6, 2007 | 12:45 AM
SPLATT's Avatar
another vote for the cats here. check em out and keep us updated. Good luck brother
Old May 6, 2007 | 07:51 AM
thechef's Avatar
Moderator
get a new MAF or borrow one and go back on the dyno i have seen this problem before
