LS6+TRAK cam+4L60 N/A & 50 shot
Well finally got to dyno my 3rd gen...
i put it on the rollers about 20 minutes after driving it...so still alittle hot,and it was in the 90's today.
All results were on a UNLOCKED converter and dynoed in second gear.
N/A results were ....
360hp/360tq
and i also accuired jets for a 50 shot, so i sprayed it for the hell of it...
388hp/415tq
Ran the car at the local 1/8 mile the previous night, and the best it went due to lack of track prep was a 7.34 @ 94mph 1.65 60ft.
From what i understand there is about a 30hp difference if you can get your converter to lock up on the dyno...is this true? If so what do you guys think of the results?
I will post the graph alittle later....
-Chris
360hp/360tq
388hp/415tq
-Chris
Originally Posted by SPLATT
man the times more than make up for the numbers. bad *** car man. got any pics of her?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
https://ls1tech.com/forums/wheels-tires/686049-3rd-gen-camaro-som-black-zr1-s.html
Originally Posted by slimcracka
shes a light weight..wonder why only 360? with that large cam and 243 heads you should be about 400 IMO.. but thats what the buttons for lol..good track times man
Originally Posted by TJ
why did you dyno in second gear?
the guys at the dyno at rpm suggested it. It seemed alittle weird to me, but i havent ever dynoed an auto myself, and didnt know how exactly it needed to be done.
id have stayed in it in 2nd and let it shift to third and completed a pull in third.
the graph would have a spike here and there, but youd have a true reading compareable to the rest of the field.
you did it at RPM?
ive heard SEVERAL people there that they WANT them to dyno in second. they dont want hi mph runs on their dyno.
"unsafe."
few people on another local board have dynoed there. this is where i get my info.
you did it at RPM?
"unsafe."
Originally Posted by Studytime
Those times would equate to 11.5s at around 117 mph. Not bad, but still not all it should have in it if you ask me.
I think it should be quite a bit faster myself.
I only have a little street tune in it from when it was running like complete ***.
(burnt spark plug wire..only 7 cylinders) and slipping tranny.
So i will have the tune finished up when i get back from Kuwait. Then see what it does.
Hey Chris,
Teresa's car traps about that in the 8th and she goes around 11.50's @117/8 mph and she dyno's around 430 locked. She also has a hell of a lot more parts than you do, lol...
BTW what does your car weigh?
Originally Posted by Spellbound
Hey Chris,
I guess i just expect alot out of the car....and i know for a fact it has more in it.
The car tipped the scales at 3150...1/4 gas, full interior.
I have two race up front now that saved me 35lbs. But i also put zr1's on the car since then with 11's in back. I think they are alittle heavyier.
3150 should be about what it is right now give or take a few.
Originally Posted by HartAttack
Hey Duane,
