TQRV2/afr205/fast90-90 ported
TQRV2/afr205/fast90-90 ported/with graph
Got my car dyno today i have stock short block,TQRV2 cam,AFR 205 unmilled with a .40 gaskets,fast 90-90 ported by vengeance raceing,Z06 maf 85mm,42# injectors,racetronix fuel pump kit,hooker headers,3"RT cats,custom 3" y pipe and open cut out,flowmaster catback,12bolt 4:11 gears. It made 436hp and 390tq. http://www.fquick.com/garages/viewga...ewimg&id=41914
what kind of cutout do you have.I had a Qtech on my car last year and was looking for every ounce of HP at the track one day and decided to unbolt it,it picked up a mph and a half,= to about 15 hp.Also the cats are hurting you a LITTLE BIT on a heads cam motor.You dont want Any restrictions in front or behind the motor.
Originally Posted by robert99ss
Thanks john, going to the track this weekend i will post my times. What kind of hp/tq can i pick up if i mill to 59cc?
what trans?
Originally Posted by 02NBMWS6
those are stout numbers for sure, but i would have expected more. My Torquer 2 cam made 432/411 with stock never removed heads and LS6 intake.
what trans?
what trans?
Tough to compare one dyno readings to another, but I would have expected a bit more too. But, let the track make your decision - or run someone with similar numbers, and don't get hung up on numbers.
I made 420 rwhp with a A4 and 3500 stall with the same heads, smaller cam, and not locking the convertor, so that's why I'd expect a little more for you.
ot sure about that cam, but I would also expect peak to be higher than 6400 rpm. Mine peaks at 6500-6600. Does the torquer peak lower?
