Torquer V.2 Dyno sheets needed..
Preferably cam only, Full exh is fine too. I am getting this cam this summer and would like to see the TQ #'s.
THanx..
it's not the exact cam you're talking about, but it will be pretty freaking close. very flat torque curve.
this was through LTs, no cats, and a single 3" dynomouth style exhaust. and was also on the stock clutch/flywheel and before the rockers.
more tuning i think i would have gotten into the 390s.
I subscribed to that other thread... Good stuff yall.. Thanx...
I can't wait!
... Since installing the MS4 on -=Modified=-'s car, I should have NO problem with this one! I can't wait to feel it and hear that 112 lope! Trending Topics
basically your setup is the same as mine with the cutout open.
interesting to see what the slight increase in duration and little bit more lift did for the HP curve. torque was nearly spot on identical. you only being down ~5# from my curve at 3K.
i wonder how mine would have done for HP if he had gone just a bit higher. and although the A/F looks good, i think some more tuning on mine would draw out some more power up top.
i REALLY want to see what she doesn now with the rockers, duals and light flywheel.
THANKS for that dyno graph
THe LS1 is a top end motor, not question about that. I want as much low end TQ as I can get from H/C. Cam for now, tho... Don't feel like going over .6 lift quite yet..
His numbers arn't all that freakish. I made similar power thru a 12 bolt.
this might help a lil
