Upgrade from P1 to D1
Old Jun 13, 2007 | 12:00 PM
Ed Blown Vert's Avatar
Default Upgrade from P1 to D1
Best I could get was 548 rwhp 563 rwtq on 10#. I didn't gain anymore boost. But under the curve I gained quite a bit.
Blue line is the P1. Red line is the D1
Don't know why I am peaking so soon.
Old Jun 13, 2007 | 12:25 PM
WHPLASH's Avatar
Seems like a nice upgrade. You gained all over nicely. But yeah, your peak is real early. With my cam, I peek at 6900 and its a little smaller than yours. I push #12lbs and see 527 rwhp on a mustang dyno.
Its hard for us A4's to make large power it seems.
Old Jun 13, 2007 | 01:08 PM
If I could peak @ 6900 I would be well over 600 rwhp.
Do you have a sheet you can post?
Old Jun 13, 2007 | 01:37 PM
Mike TexaSS's Avatar
8 Sec Tuner
Have you logged boost? Blower cars should never stop pulling!
Old Jun 13, 2007 | 01:56 PM
Next time I dyno I will. My friend was watching the boost gauge. It immediately went to 10# and held then finally hit 11# at the end of the run.
Old Jun 13, 2007 | 02:02 PM
WHPLASH's Avatar
Just had it dyno'd a week ago. Man does it just pull. I have no idea how you get your pictures so big. lol
Old Jun 13, 2007 | 02:15 PM
Nice.
I have been looking at other sheets, and most of the time I don't peak as high. But under the curve I have quite a bit of power.
You have 300 rwtq @ 4000 rpms and I show 550 rwtq.
Old Jun 13, 2007 | 02:17 PM
WHPLASH's Avatar
Because you're strokin'. Alot of torque with that 383.
Old Jun 13, 2007 | 02:18 PM
I guess I can't really complain about the peak power. Torque is what I want.
Old Jun 13, 2007 | 02:24 PM
WHPLASH's Avatar
Like I said, A4's don't show the power. Its hard to compare to M6 dyno numbers.
Do yo spray your car often?
Old Jun 13, 2007 | 02:39 PM
Slowhawk's Avatar
LS1Tech Sponsor
The Cam is making it peak early.222 Cam in a 383ci is pretty small.Makes a good average power though.
Old Jun 13, 2007 | 02:43 PM
WHPLASH's Avatar
Is that the cam from your old setup?
Old Jun 13, 2007 | 04:41 PM
When I picked out the cam, I forgot when you have more ci. You need more cam. I was keeping in mind smog, which why didn't go too big. But now after seeing the dyno, I should have went with something like 224/230 on a 115
The old setup had a TR 224 on a 114. That one peaked around 6000
Old Jun 14, 2007 | 08:20 PM
Slowhawk's Avatar
LS1Tech Sponsor
Truthfully I would boost it more.Try to get 14-16lbs and run pure methenol from a Alky control kit. Will still be reliable and will put you at or near 700rwhp with awesome midrange.
Old Jun 14, 2007 | 08:57 PM
I wish I could boost it more, I already have the smallest pulley on the blower a 3.2"
Old Jun 15, 2007 | 07:18 AM
No Juice's Avatar
Something doesn't seem right. Regardless of the cam that is in it, I would think with the smallest pulley you should see more than 10# even on a 383. I would definately swap to the 4.5" IC's.
Old Jun 15, 2007 | 07:43 AM
WHPLASH's Avatar
They do make a 3.0"
I'm guessing here. You probably have a 6-rib setup w/ a larger crank pulley. I would think also, if this is what you have, that you're slipping.
I just tried a 3.5" pulley with a MMS crank pulley and could not get it to grip. The belt was slipping and got shredded. I need to upgrade to a 8-rib setup. I have a 4" on now and seeing 12 lbs.
Old Jun 15, 2007 | 08:40 AM
I was expected more too. I am debating on the 4.5" or FMIC.
They do make a 3.0"
I had the 3.0" in there first, but swapped to the 3.2 to see if I was slipping. No change in boost.
I am running the SDCE tensioner with a 8 rib belt.
Old Jun 15, 2007 | 08:50 AM
WHPLASH's Avatar
Then that don't seem right then. I think KP was seeing 15+ with the 3.7"
Old Jun 15, 2007 | 09:27 AM
hosspowerinc's Avatar
Im not quite sure whats wrong with 548 rwhp 563 rwtq????
