New 402/L92 Results
Old Jul 26, 2007 | 07:11 PM
  #81
1997bird's Avatar
Originally Posted by edcmat-l1
AAAHHH, vindication for Patrick I guess....
I would be wondering who stole the rest of my HP.......
Ed, give it back you theif!!
Old Jul 26, 2007 | 07:14 PM
  #82
edcmat-l1's Avatar
Hes gotta come n get it!!
Old Jul 26, 2007 | 07:31 PM
  #83
NEVRLIFT's Avatar
Hmmmm...where could your power be?
Old Aug 3, 2007 | 10:03 PM
  #84
chae's Avatar
Someone local made 475 RWHP with a 370.
Old Aug 5, 2007 | 10:06 PM
  #85
Shoulder Shaker's Avatar
Wow. I was expecting more. Well if it drives good to you, enjoy.
Old Aug 9, 2007 | 05:55 PM
  #86
RGKSR's Avatar
Default I was expecting more too!!!
I'm getting another .015 milled off the heads (64cc chamber) and switching to a .041 head gasket.
I hope this improves the torque.
Bob K.
Old Aug 9, 2007 | 09:22 PM
  #87
94 guy's Avatar
how much has been milled off the heads? do you have to mill the intake to correct for the head milling?
Old Aug 9, 2007 | 09:27 PM
  #88
94 guy's Avatar
who ground the cam for 2c5s?
Old Aug 12, 2007 | 02:51 PM
  #89
WizeAss's Avatar
Originally Posted by RGKSR
I swapped the cam last week. I just walked in the door from getting the car tuned.
The Patrick G. cam made more RWHP (460 vs 451) and RWTQ (421 vs 414).
I am happier with the newer cam as I feel that it is more driveable down low.
I can cruise @ 1K, and it pulls cleanly. I think if I was going to race the car, I might put the 1st cam back in.
Like I said in the very 1st post, I was never unhappy with the cam, but the L92 heads are still new and I wanted to play.
Who knows, next maybe a different set of heads? I just want good power under the curve.
Bob K.
I made it to post 79 before feeling the need to reply to this tread.
I looked at your graph..... armchair QB time for me.
1. You need to check Lash and Coil Bind on your springs.... I bet money those springs are all over the place.
2. You NEED 1 7/8 headers for L92/LS3 heads... they beat AFR flow numbers on the intake.... so what!? They flow 48cfm less at .600 lift than AFRs. Help those heads.... get an exhaust that flows freely and prevents reversion/backup etc etc.
3. What pushrods are you running... I hope it is not 7.4's..... after checkin pushrod length the shop working on mine found that you need shorter pushrods for the L92/Patriot Extreme combinations. Think of too much spring control as a slinky... the longer the more it moves... the tighter the more control on the valvetrain.
Good luck.
I think you should be making about 510rwhp with the right headers, and a better intake. I am not fond of the L76.... not yet anyway.
Old Aug 12, 2007 | 04:52 PM
  #90
red beast's Avatar
I called comp cam and they custom ground mine...It's pretty close to yours the only difference is the hairdryer...you should put one on yours....
Old Aug 13, 2007 | 12:31 PM
  #91
RGKSR's Avatar
Default I'm always willing to listen!
I'm always willing to listen.
The springs were installed and set up by a local shop, but you make a good point.
I kept the 1 3/4 for torque. When I was at Cartek, they said that the 1 3/4 headers were not a problem. Maybe I'll get some 1 7/8 ARH/LG/Kooks in the future.
Pushrod length was checked at the shop that set uo the heads. Now I'm getting the heads milled and installing thinner head gaskets, so I'll recheck the pushrods.
Good luck.
I'm hearing rumors about a FAST L92 compatable intake. My problem is there's not much clearance under a C5 hood.
I still feel that there is power somewhere that hasn't been found.
Bob K.
Old Aug 13, 2007 | 02:40 PM
  #92
2c5s's Avatar
It's a Comp. If you're asking who spec'd it, I did.
Old Apr 10, 2008 | 10:44 PM
  #93
bifster's Avatar
Here's the flow numbers for the L92 heads.
Intake
.100 .200 .300 .400 .500 .600 .700
77.63 155.25 226.91 277.96 323.81 346.30 357.54
Exhaust
76.26 133.46 171.59 200.19 219.25 225.61 228.79
Max,
Thanks for posting the dynograph!
Bob K.
Are these the ported numbers? seems high for stock flow numbers..... thanks
Old Apr 10, 2008 | 10:49 PM
  #94
bifster's Avatar
sorry i dont knwo what im talking about just let me know if this is ported or non ported numbers lol thanks
Old Apr 11, 2008 | 11:38 AM
  #95
WizeAss's Avatar
Geoff, I ordered a smaller sized cam from Synergy.... for 2 reasons:
#1, I will always use a nitrous converter and wanted to improve low end torque, it has been proven that big cams move power up... not down.
#2, I have discovered that due to the 265-270cc runners on this head, getting the velocity back in the head from the huge ports will require less overlap and less duration with perfectly designed seat timing events. It is also apparent that a split is not needed as much after reducing the valve size on the intake and fully porting the exhaust for max effort.
based on these two things and wanting to have a nice idle for the street....
I believe my cam is a 23X/23X and will have a dyno today or tommorow :crossesfingers:
Old Apr 13, 2008 | 12:47 PM
  #96
AustinDesigns's Avatar
Did you get it dynoed yet? I will also be ordering my cam from Synergy. Rick seems to have the L92's figured out pretty well. My engine builder has ported a set of L92's already, and they BLOW RGKSR's out of the water 20-30cfm across the board. So if we can get a well designed cam, it should make for some good numbers. I'm also considering selling my L76 and buying a carb style. But I want to see what the L76 will do first. Looking forward to your numbers!
Old Apr 14, 2008 | 09:07 AM
  #97
edcmat-l1's Avatar
Big huge flow numbers havent proven to be equated to big huge power in these heads simply because they seem to flow just fine for the size engines they're being used on. That and the fact the intake (l76 at least) doesnt support huge flowing heads.
Now that being said, if you're putting them on a solid roller 454 with carb intake, then your huge flow numbers may make huge power.
Old Apr 15, 2008 | 12:19 PM
  #98
WizeAss's Avatar
I wouldnt make the intake ports a bit larger for a 370.... if your ported did more than a valve job and exhaust port work you are going the wrong direction.
Also..... the problem with this head is the port is just to small for NA applications. It is better suited for Nitrous or FI. Now if you put a 454 or a 427 and/or spin some serious RPM's on a 408 it will be the perfect head!
Unfortunately my combo is less than optimal. TH400 trans with a nitrous converter, GMPP intake that kills lowend torque, and me wanting to drive it on motor and the bottle. Mix all that together and the only option is a more streetfriendly cam with little overlap. This is what Rick at Synergy explained to me to sum things up.
Old Apr 15, 2008 | 02:11 PM
  #99
94 guy's Avatar
wize when do you think the dyno will happen for you?
Old Apr 15, 2008 | 08:08 PM
  #100
WizeAss's Avatar
Tuner is tuning it as we speak... I will call tonight and get an update.
By Brett Foote | 2026-06-04 05:00:17
