Lingenfelter Heads/ Joe O. cam/ 175 Shot / Stock Bottom End LT-1. 608rwhp / 657rwtq
I went to the dyno today .. The car has an untouched from the factory stock bottom end.. I have Lingenfelter ported heads and Joe Overton did a custom grind cam. Eric Bradley ported the intake, throttle body. This setup has been in my car for almost 4years . I converted the car from an auto to a 6-speed and added a strange 12 bolt... The car dynoed N/A 416.4rwhp and 398.7rwtq after it was tuned a little.. Then i made one run with the spray and made 608.9rwhp and 657.4rwtq.. I am very happy with this setup .. This is a full weight convertible with a/c and everything that came on it from the factory.
Thanks Chris
Thanks Chris
Sick.
I can't wait to spray my LT1. With 128k on the stock bottom end and 55k on the heads/springs, it still put down 388/381 to the wheels.
After running my cam only LS1 on the HSW 15-0 shot the other day and seeing 492/511.....I can't wait to see what the LT1 will do.
CONGRATS!
CONGRATS!
Originally Posted by WKMCD
Just curious as to what size shot you pushed.
I sprayed a 175 wet shot with 6.6 degrees of timing pulled out..
Thanks Chris
Originally Posted by Hardtop00SS
Isn't Eric the guy that works for Joe porting heads,etc?
Awesome #'s
Awesome #'s
Chris
Originally Posted by LPE Z Convt
Yep thats Eric B. he is a good person and knows his ****.. I believe Eric B. works from his own shop though..
Chris
Chris
yea that's right, Joe just gives him work. I live about 20 mintues from Joe's shop, I might get him to do something with my SS.
Chris
Thanks Chris
Thanks Chris
not 7, not 6, but 6.6. LOL!!!
Not sure if you are 'allowed' to tell me but, what are the specs on the cam you are running? If you don't want to post it, I'd appreciate a PM. Reason is I am looking for a stout cam to replace my dinosaur CC306.
Originally Posted by SPDEMON
6.6 degrees huh?
Yes, 6.6 degrees haven't you ever heard of an MSD digital-6 plus ingn. system?
I can adjust it from .1 degrees of retard to 9.9 degrees of retard.. As far as the cam specs it was more than just the cam that created the power.. I will tell you this your cc306 is a bigger cam than mine..
Chris
Originally Posted by Rob
Nice setup! Can you post the graph? I'd like to see the curves on that thing. I might do something with an LT1 again and it would be great to see how it looks.
Chris
