dyno results - H/C, bolt-on Z06
Originally Posted by zo6racerx
Thanks. The specs................232/240 595/608 on a 114
As promised, here is the dyno file for my car. I dyno'd the car at Hybrid Dynamics in Youngwood, PA. My buddy Dave tuned the car with HP Tuners and we used my wideband (that is why you don't see it on the sheet). The air/fuel at WOT was rock steady to red-line @ 12.98. The temp and humdity at the time of run was 92 degrees and 17%.
1 Post
Glad to see you got the graph posted. I had your back bro if you didn't get it figured out. You are making excellent torque. 360 rwtq @ 2800 rpms. I bet your car would be with me all the way until we got into 5th gear. I make very similar numbers just mine ramp up faster and higher once above 4000 rpms. Have fun and get some video of that beast.
Doug,
Can you post your dyno graph so I can compare? Or can you point to where I can find it on the forum?
John
1 Post
John I emailed you one of my graphs before the larger MAF went in and before the tune was finalized. Did you get it and what do you think?? It gives you an idea of what that R&D cam can do as far as making power and torque. I'll try to get the one with 490/445 at the wheels ...
