my home ported fast 90/90 results
my home ported fast 90/90 results(with graph)
Well i gained 20 rwhp and 17 rwtq.I made 421 rwhp before and 441 rwhp after.
I started making gains after 3000 rpms.I will try to get a graph up later.Not bad for a 228/230 cam on xe lobes with 570 lift.The temp and humidity were the same on both runs.same dyno too.
1 Post
That is pretty good for doing it yourself. Congrats !!
Did you learn a few things in case you generate any interest by other people wanting their intakes ported by you ?? You could make a few bucks. Good luck and again congrats on the good results.
yeah i learned that keeping the runners as straight as possible is what has to be done.Its not easy and i wrote up a how to for people who want to give it a try.here is the link https://ls1tech.com/forums/showthrea...4&page=1&pp=20
Vengeance does it for a fair pirce in my opinion.It takes some time and finess to get it done.thanks for the complements
Excellent numbers. What was your tq?
no its going from a ls6 intake/ported throttle body to a ported fast 90/90
by the way Bo my heads are not being pushed to there limits yet with the cam i have.Someday when i get gears and a 12 bolt i will put in a cam to take advantage of my heads.They are being cut a little short right now with the 570 lift.
Originally Posted by pdd
GREAT JOB you made more torque than me. mines missing somewhere
Don't want to hijack, but did you degree you cam. On stock heads I went from 358 not degreed to 382 degreeing my 228/232 on 110.
