*RESULTS* 402/Livernois L92s/Patrick G cam
Originally Posted by allngn_c5
Hey bro, I haven't heard from you in a long time. I sent you a PM. CONGRATS on all the horsepower your new engine made. We didn't get to run last year, and I kept missing you at the 50's McDonalds. I still owe you a ride. By the sounds of the power you are making I can't wait to go for a ride. Actually a bit afraid to run you. Your new motor sounds like a beast. Don't worry about that 10 bolt, she'll last until you race from a dig. 474 rwtq is a lot of grunt. So get ahold of me, I got the itch to run bro.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
ya, my stock 10 bolt is going to hate me, 3.42 gear isnt helping out to much either, but we can run em one day
Originally Posted by CaMaRo67RS355
maybe u should look into the new kooks 2" headers
Originally Posted by Patrick G
Justin, great results, especially considering all the power mods you still have left to do.
Larger headers (big gains here)
Ported intake manifold (another biggie)
UD Pulley
Larger MAF or no MAF
Electric water pump
Shaft mounted rockers
The fact that you exceeded 500 rwhp so easily speaks volumes of how well the L92 heads work. How's the driveability of the car right now? Can't wait to hear about the power once you put the big shot of spray on it.![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
UD Pulley
Electric water pump
once u get all that u'll be pushing some serious hp + the nitrous even more
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
Originally Posted by JDP
ya, i was thinking they would be overkill, but im sure they will be perfect with a big shot once i spray it
i did some research about them but for my 346 heads/cam/nitrous setup they are still on the big side ill probably stick with my 1 7/8's
once u get all that u'll be pushing some serious hp + the nitrous even more ![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
While I am certainly the last person here who should question Patrick's cam spec for you, and he's helped me a ton too.. I think you would make much better numbers closing the intake valve sooner to avoid reversion and advance the ICL since the L92's runner CC is so large and air velocity is low. Yes, the L92's are very exhaust weak compared to the intake side, but instead of increasing duration for an earlier EVO, you are already advancing the ICL which with the same cam will make the EVO earlier as well (less gas pumping loss since you need more flow out of a smaller hole per say, it will take more craskshaft degrees to accomplish). I'd try a cam with a smaller exhaust lobe and a lot more advance. Something along the lines of a 240/246 112+5 or 6. I think it would work better than a large split. But I also don't know what goals you had in mind for your car, which could influence the cam choice. Patrick's knowledge is indespensable on this site, I just look at the L92 head a bit different. I would take the existing cam and advance it another 4 degrees if I couldn't swap the cam out. I'm not trying to insult anyone, I'm just offering my view.
LS1 Tech Administrator
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
#32
would be a fast car if my dumbass got rid of my built t-56 and put a th400 in it, but im addicted to the stick shift cars
im with u i love a 6 speed but it does have its limitations
#34
Originally Posted by HUGGER ORANGE SS
What kind of compression ratio are you running?? With the .661 exhaust lift I'm sure he's running a lower compression motor or the pistons needed to by fly cut to clear that kind of exhaust lift.. just asking..
That is a GREAT NOS CAM.. damn...
and ya, cam is meant for a pretty hefty shot
#36
What you're not seeing is that this is not an NA cam. If it was, the valve events would be different, especially on the exhaust. This cam is a nitrous cam designed for a 300 shot. You don't have all the information so you can't be expected to see what's on the horizon. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I was wrong and I didn't have the all the info.. and I certainly wasn't trying to ruffle any feathers.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#39
Originally Posted by 383ss
I didn't gain any peak hp going from 1 3/4 to 1 7/8 on my 408. it did pull about 500 more RPM though.
__________________
#40
Originally Posted by Chad@LivernoisMotors
Rode in it last night. Car is NASTY. Congrats Justin. It's alllllllllllll about the heads.
Chad @ Livernois Motorsports
car feels **** wide open, sounds **** too, need to get some soundclips up.
